Blanks
- hedge
Re: Blanks
It's options like tpms (tire pressure), taxi light etc, the second picture is heated rear window, and the sides is heated seats
- tommyzooom
Re: Blanks
It would be nice to find a part No. for a blank switch, to fit in the gap shown beside the asr, If I can find one I have a plan to wire up my garage door opener to it, OEM stylee
- Adam87
Re: Blanks
Think the oem garage door/gate opener (home link) goes in the sun visor
- Timmyd
Re: Blanks
I have similar plans, will post if I find it, sent a few emails today enquiring.tommyzooom wrote:It would be nice to find a part No. for a blank switch, to fit in the gap shown beside the asr, If I can find one I have a plan to wire up my garage door opener to it, OEM stylee
- Adam87
Re: Blanks
the tpms (tire pressure monitoring) button only needs 4 wires to have it working properly if thats what you wanted to put there
Re: Blanks
where is 14 and 55 at?
- Adam87
Re: Blanks
Cecm and abs module, can get the pin numbers if u want them
- Adam87
Re: Blanks
number 55 goes into the instrument lighting circuit which can be taken from the switch next to it
number 14 goes to fuse board to a 5A fuse
the middle wire goes to ABS module to pin 41
- Br3cht
Re: Blanks
Is TPMS available on all caddy's?
Or possible for retrofitting?
- Adam87
Re: Blanks
I think the abs modules on the early caddy don't support it but later one do, not sure what year from, but if you changed abs module then yeah definitely can
- smartezippo
Re: Blanks
Interested in this, I wonder if the abs module in my 2008 supports this, I can only find the narrower tmps button I don't think there is a wide one for the two button dash, may have to change it to a four button and end up with 2 more blanks
2008 1.9TDI, DSG, Factory Appearance pack, Elec Pack, Paddle shifters, multifunction leather wheel, Highline Touran Clocks, Cruise control, Golf mk5 GT seats, Touran Door Cards, Touran front button DSG Shifter, R32 Pedals........
- Adam87
- Sabbunsingh
Re: Blanks
Did u ever get any more info on these abs modules and tpms compatability?
Re: Blanks
Hi Did you run TPMS
How do i have my my2013 caddy active tpms
