I changed my CECM for a 30 byte bad boy today, everything went well recoding but for some reason the bulb out warning light is showing on the dash, i have checked all bulbs and see no problems! any ideas how to reset? thanks guys
BULB OUT DASH WARNING LIGHT?
- Timmyd
Re: BULB OUT DASH WARNING LIGHT?
Does the VCDS fault scan not show which bulb is the problem?
- Timmyd
VCDS fault scan showed all bulbs were out! i cleared faults, re scanned and everythings fine now! very strange!!Doc wrote:Does the VCDS fault scan not show which bulb is the problem?
- Adam87
It will show all bulbs out until cleared because you've unplugged every light on the van by removing the cecm so once cleared all should be good
- Timmyd
that explains it, thanks mate, also did the brake light as rear light adjust that i saw on one of your posts, looks really good.. to quote someone else a "nice touch to the rear end"
- Adam87
Welcome mate, and glad you liked it
is your cluster all red?
- Timmyd
red needles, numbers, lines between numbers, and be-"low line" screen, warning lights are in yellow. soon to be "highline thanks to spacewalker and Doc!
- Timmyd
a quick pic of the rear light adjustment...
