What tyre pressure would you use??
Hi, just picked up my 09 caddy which has 225/40/18 on 18" Audi rims, I know these tyre's off tern look like there flat, but what pressure would you use?? Not much kit in the back so mostly running empty.
Dominic
Dominic
- Banditbarron
- Sales Caporegime
Re: What tyre pressure would you use??
Go off what the original pressure should be according to the data plaque
Either in petrol flap or door opening
Dave
Dave
There is no need to change from the labeled pressures on the door post. I've run them on 225/40/R18 for 37,000 miles and they are spot on IMO.
After 37,000 the fronts measured 2.0-1.6-2.0 (outside-centre-inside) and rears 5.0-5.0-5.0.
Fronts were maybe slightly over inflated but over 37,000 your talking 0.1 or 0.2 PSI.
60% motorway driving with 100-130kg in the back.
Thanks for that, they were very low. The plate gives a range of 30-36 for the front and 35-41 for the rear obviously on much narrower tyres ith higher profile and smaller wheels. I've gone for 32 at the front and 36 at the rear. Anyone think I should lower or higher it let me know.
Dominic
Dominic
- dooka
Now, that is a lot of shrooms ..Doc wrote: 60% motorway driving with 100-130kg in the back.
36-41 rear
Just measured mine and they are 30/30 front 35.5/35.5 rear.
Maybe a little under inflated on the rear but with even wear I'm not complaining.
I tend to go with 34 front and 36 on the rear
It depends on the tyre size and profile. I run 40psi on the fronts which are 225/35/19
A friends rs6 runs 275/30/20 and they run 50psi. Much bigger and heavier car I know. A scirocco on standard 18's runs 40psi too.
Interesting, what's your wear pattern like running 40psi. As you can see I did 37,000 miles at 30psi with only 0.4mm extra wear in the centre, showing I was over inflated at 30psi.
- stu0468
I run 38 - 40 psi in my 215 and 225/35/19. cats eyes are too painful any less. my fronts wear on the inside edge as the cambers way out.
Ill get some tread depth measurements and let you know skipper. From the naked eye they look perfectly even.Doc wrote:Interesting, what's your wear pattern like running 40psi. As you can see I did 37,000 miles at 30psi with only 0.4mm extra wear in the centre, showing I was over inflated at 30psi.
Sounds like I'm in the ball park. Will keep and eye on it!!
