Rough Idle Caddy BJB 105 tdipd
N14LLd
Post by N14LLd »
So I just bought this caddy in real bad condition. previous owner was a farmer didnt really care about it.
first of all I scanned it and low and behold, all four glow plugs, water temp sensor and fuel temp sensor all gone.
changed all of them.... seamed to do the trick. few mile down the road rough idle again..
scanned it, was coming up with misfire cylinder three. after inspecting the cam I changed it for brand new cam and lifters the black ones..... still no difference in idle even tho cam and 3 lodes were worn.
Oh checked torsion on VDCS it was -2.9kw. I fixed that now sitting at 0.0kw... man that was hard to get precise. still no difference with idle.
eventually I changed all four injectors of ARL ones.... lovely job Idle is lovely driving like a dream....until she heats up. now cold or warm its like Im back to square one.
scanned it to night this is what it come up with.
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 DM HW: 028 101 188 2
Component: R4 1,9L EDC G010SG 6045
Revision: 12345678 Serial number: VWZ7Z0D0222251
Coding: 0050031
Shop #: WSC 66565 257 00032
VCID: 71E3CB1D68B23B1
1 Fault Found:
16687 - Cylinder 3
P0303 - 000 - Misfire Detected - Intermittent
Freeze Frame:
RPM: 819 /min
Torque: 24.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Inj. Quantity: 2.92 mg/str
Temperature: 77.4°C
(no units): 0.0
Readiness: 0 0 0 0 1
Did Mes Block on engine to..
VCDS Version: Release 11.11.3
Data version: 20120401
Address 01: Engine (03G 906 016 DM)
20:40:59 Group 004: Pump-Jet Valves
798 /min Engine Speed (G28)
0.6 °BTDC Injection Start (specified)
7.1°KW Injection Duration (specified)
0.0°KW Torsion Value
20:40:59 Group 013: Idle Stabilization (Injection Quantity Deviation)
2.99 mg/str Injection Quantity Deviation Cyl. 1
-3.01 mg/str Injection Quantity Deviation Cyl. 2
2.99 mg/str Injection Quantity Deviation Cyl. 3
-3.01 mg/str Injection Quantity Deviation Cyl. 4
Any kind of help would be great.
Re: Rough Idle Caddy BJB 105 tdipd
Your idle stabilisation is off the chart bud, it should be + or - 0.5 at the most.
Looks like they are going crazy, trying to correct something.
Crank sensor ok?
minibikepro31
Post by minibikepro31 »
injector leaking or somthing as simple as a fuel/ air filter needed?
IN THE BOOST!
N14LLd
Post by N14LLd »
Ive changed the air and fuel filters but no thinking about it. the engine cover has wore a hole in the air pipe. after the sensor. wonder would that count for something.
I have a tuned file in the van and the tuner said he can try and work something for the new injectors.
Is there any way of telling if the injectors are leaking? its not filling the sump.. Ive seen that happen before.
Would a faulty crank sensor not come up on the VDCS scan?
Crank sensor may be giving wonky readings and the ECU is over correcting. The injector stabilisation is only done at idle, is that when you notice the problem most? Drives OK?
minibikepro31
if you have a hole in the air intake pipe after your mass air flow sensor i would say thats your problem.
with the above scans you have put up its showing engine speed that is the crank sensor i think G28? so i would say thats ok.
have you drove the van? dose it surge on power underload
IN THE BOOST!
N14LLd
Post by N14LLd »
Right that will give me something to do tomorrow. get a new pipe.
Drives the very best, sometimes very easy to stall when its warm. I think due to the misfire.
I think I will get onto the tuner and fix the pipe tomorrow if that doesn't solve it ill look into the crank sensor.
Thanks for the info lads.
fenwick458
Post by fenwick458 »
does it drive ok?
how have the injectors been set up?
i don't think it's going to be something like the maf or a split boost pipe, that would cause it to be gutless but not rough and missfiring.
something to do with the fuel system i reckon. but more logging is needed first
N14LLd
Post by N14LLd »
Fixed my air pipe yesterday. Took it for a wee cruise last night.
Its weird for once cold it starts 1st time. but rough idle. Then once drove for a while idle is perfect and driving perfect. bad and good driving comes and goes.
when its driving bad it is acting like a really really really bad flywheel.
I quarter miled a 143 audi a4 last night. he says there is a puff of white smoke every so often amongst the black as if its off a cylinder.
I was talking to a fella he says on the rollers for the injectors some times need screwed down so the injector is getting pressed enough.
Ive changed injectors before and never done this. any one else heard of doing that?
fenwick458
how did you set the injectors up? from memory you tighten them down fully and then back off 225degrees an each one with them at TDC.
N14LLd
Post by N14LLd »
yeah man I did that carry on.
Could there be damage in the cylinder?
fenwick458
possible yeah. it's either going to be 2 things i reckon:
1- mechanical damage to one/some of the cylinders/pistons head/valves/seats etc...
2- a blockage or fault in the fuel system.
an from them i reckon it's going to be number 2.
N14LLd
Post by N14LLd »
right. Im going to get the Tank out tomorrow and give it a good clean, blow out the fuel lines. and change filter.
Couldnt do any harm?
N14LLd
Post by N14LLd »
Has anyone heard of changing the injector harness to clear a few faults?
Yup, it is something that gives trouble on these engines. ;)
