I'm hoping someone may be able to help or point me in the right direction:
I have had an issue with my side loading door and the warning light appearing for no apparent reason identifying the side door is open when it clearly is not, I have tried numerous times to fix it with altering the catch and minor adjustments on the lock etc, all to no avail. This was not really an issue that caused me a great deal of concern until I installed highline clocks and now it continually beeps, is there a solution available to code the door out, I remember seeing a build thread on here when a member had removed his side loading door altogether and as such had to code out the door.
Any help would be appreciated as it is now driving me crackers!!
Shaun
Caddy Side Door
- bisoncaddy
Re: Caddy Side Door
You need a new side door switch.
Nickic did a how-to recently with part numbers and price.
- bisoncaddy
Re: Caddy Side Door
Cheers Doc, I'll give this a try
Shaun
Shaun
