Rear wiper
Re: Rear wiper
Any idea when these will be despatched?
Re: Rear wiper
Should have it in the post tomorrow, replenished my stationary today so I've got something to send it out in.
Anyone else want one while I'm at it, I've got about 5 left?
- ed1119
Re: Rear wiper
Cheers Doc.
Re: Rear wiper
Hi can I have one what shall I put in the PayPal comments? Thanks
Re: Rear wiper
Your address would be useful.
Re: Rear wiper
Payment sent if you can confirm that would be great thanksDoc wrote:Your address would be useful.
Re: Rear wiper
Got it, will send out tomorrow.
Re: Rear wiper
I wonder (even more coming from Southern country) Why is it so popular this mod, I mean , whats the real purpose of doing it if wiper would work correctly?
Regards and thanks for answering
Re: Rear wiper
Because to spec some options, you are obliged to have others without being able to remove them.
EG, if you want climate, you have to have heated rear window, heated seats and rear wiper.
I don't need to see out of the back window and need the load area secure so i have limo tints, and window guards which makes the wiper look a bit out of place.
Re: Rear wiper
I see, was not sure if it meant the implementation of something else ( beside spec options). Thanks for comments
Re: Rear wiper
Thanks Doc,
Received today.
Received today.
- ed1119
Re: Rear wiper
Thanks Doc, received mine too
Re: Rear wiper
Just fitted mine, however....
I'm not sure if this has been mentioned but Mine is a 2017 high line and to remove the wiper motor, you will almost certainly have to remove the cast handle back plate via the two bolts inside the door as the motor will not come out without doing it!
You may also need to remove the long link rod that's attached to the front of the lock mechanism to allow you to push the handle down enough.
Re: Rear wiper
Yep, it's next to impossible to get the motor out without undoing the handle.
Make sure you get the rubber seal on the rear key barrel in the correct position too, it can easily cause problems reassembling the handle/lock.
