having trouble with my cruise control mfsw all working says ccs defective I have 1 that's tested working in other car and tests not in van ???
my guess its the code any help welcome
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 855 0111
Coding: 0000732
Shop #: WSC 01324 785 00200
VCID: 78F5F6390BC86A9
Subsystem 1 - Part No: 3C8 959 537 D
Component: E221__MFL-TK6 H06 0022
Coding: 00000226
Shop #: WSC 00000
1 Fault Found:
00895 - Cruise Control Switch (E45)
014 - Defective
vcds code help
Re: vcds code help
Was it tested with that SWCM? Thinking maybe a comparability issue.
Re: vcds code help
001384 - Cruise Control Switch (E45)
P0568 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
come back with this using golf swcm
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Re: vcds code help
Check measuring blocks on SWCM, see are all the functions of the switch working.
What year is the van?
Pre September 2006 will need an extra wire from SWCM to ECU.
