Canbus gateway upgrades ...
b1ackb1rd
Post by b1ackb1rd » Sat Nov 02, 2013 8:47 pm
Evening all, first post .... I'm on here as a Touran owner curious as to what you guys do to your Caddys as the Touran scene is a bit tame in UK.
Anyway, I came across something yesterday when getting my mechanic to fit and code a new spec canbus gateway before I fit a new RCD310DAB stereo to my poverty spec 2004 Touran ...
The mechanic connected the car to Autologic diagnostics which reported a canbus gateway firmware update was available ... I was dubious because EVERYONE says a new higher spec canbus has to be fitted to avoid overnight battery drain when fitting the next generation VW stereos, however I was persuaded to give it a whirl.
Stereo fitted and works beautifully even the DAB using the standard window aerial, and I had an anxious night wondering if the old girl would start so I could get to work this morning.
I had no faith in this firmware update but it seems to have worked, the car started beautifully this morning, no sign of battery drain.
I would recommend this solution to anyone upgrading stereos it's a bloody site easier than stripping the dash, or crawling under the steering wheel and makes upgrade VW stereos a real option for all mk5 platform cars.
Poverty spec 04 Touran owner, BKC, 105hp - I'm here on missionary work
VW Golf Plus 06, BKC, 105hp
1963 Morris Minor
AutosoundBlackpool
Re: Canbus gateway upgrades ...
Post by AutosoundBlackpool » Tue Nov 05, 2013 10:30 pm
b1ackb1rd wrote:Evening all, first post .... I'm on here as a Touran owner curious as to what you guys do to your Caddys as the Touran scene is a bit tame in UK.
That's a great bit of helpful info.
It doesn't work on all gateways but its always worth checking the number of the module because a lot are upgradeable.
The Fylde Coast No1 in-car Electrical Specialist
Cobra Autowatch JL Hertz Pheonix Gold Kenwood Steelmate Parrot
http://www.autosoundblackpool.co.uk" onclick="window.open(this.href);return false;
07973 353632[/color]
https://www.facebook.com/pages/AUTOSOUN ... 6593764755" onclick="window.open(this.href);return false;
https://www.facebook.com/groups/vwretro ... ment_reply" onclick="window.open(this.href);return false;
FREE VCDS / VAGCOM READOUT - Just call to book - QUOTE CADDY2K
MEMBER DISCOUNTS - WANT CHEAP STUFF? JUST ASK!
b1ackb1rd
Post by b1ackb1rd » Thu Nov 07, 2013 1:38 pm
My canbus was upgraded using Autologic, is it possible using VCDS?
My cable arrived yesterday !
1963 Morris Minor
Who is online
Users browsing this forum: No registered users and 1 guest
