what wheels will fit
- caddyirl
Hi all,
buying a new set of wheels and just need some advice, they are 225 40 r18 will i have any issues fitting these to a caddy? And will the low profile tyre give a rough ride and should i go with a smaller option? any thoughts suggestions welcome
- dubvan
Re: what wheels will fit
Are you lowered. Had 18's with eibach on previous caddy and was fine with ride.
Jonesy
Jonesy
- caddyirl
dubvan wrote:Are you lowered. Had 18's with eibach on previous caddy and was fine with ride.
Jonesy
not lowered ridding at standard height
- dubvan
I'm currently on 19's with standard height and still have all my fillings!
Jonesy
Jonesy
Mine is standard ride hight, on 225/40 18's, (ET45), and rides very well.
- caddyirl
any chance you could throw up a photo to see the 18's on the standard ride height?Reggie wrote:Mine is standard ride hight, on 225/40 18's, (ET45), and rides very well.
First post on page 2 of this thread, the 'Shine On' sign written van.
http://www.caddy2k.com/forum/viewtopic. ... 8&start=15
- Banditbarron
- Sales Caporegime
- caddyirl
Banditbarron wrote:Size is irrelevent however the offset is vital
what offset should be used?
- dan@biali
We also need to know the width of the wheel but I'm assuming with 225 tyres its an 8" wheel. I run a 19x8 wheel with an offset of 48 I think and no clearance problems.
- caddyirl
dan@biali wrote:We also need to know the width of the wheel but I'm assuming with 225 tyres its an 8" wheel. I run a 19x8 wheel with an offset of 48 I think and no clearance problems.
ya the wheels are 225 40 r18 so that would be 18 x 8"
Just found out the offset is et42. Will that 5mm make any difference?
The tyres are 225/40-18 not the wheels... the wheels are most likely 18x7.5 18x8 or even 18x8.5
I think ET45 is about the optimum offset
- caddyirl
Please read the post above yours . Wheels are 18" x 8C8COG wrote:The tyres are 225/40-18 not the wheels... the wheels are most likely 18x7.5 18x8 or even 18x8.5
I've 225/40/18 tyres on my 7.5x18 wheels so if your guessing the wheel width from the tyre size you may be incorrect.
- caddyirl
Point taken, any dealings with tyre safety centre in cookstown doc?
