rns510 versions
rns510 versions
Been looking to upgrade to a rns510 headunit for a while, but I'm confused by all the version numbers available
Anybody know the difference, and am I better off going for a certain version number?
Re: rns510 versions
I have been looking too but read these can drain the battery unless you change the canbus (not sure what a cunbus is)
- smartezippo
Re: rns510 versions
I've just put in a 310 dab, apparently these cause drain too but touch wood it's been ok for 2 days. Not sure how strong the drain is. Ie. will the batt be flat after one night?!
2008 1.9TDI, DSG, Factory Appearance pack, Elec Pack, Paddle shifters, multifunction leather wheel, Highline Touran Clocks, Cruise control, Golf mk5 GT seats, Touran Door Cards, Touran front button DSG Shifter, R32 Pedals........
- AutosoundBlackpool
Re: rns510 versions
The drain is really severe so you'll know if you have it!smartezippo wrote:I've just put in a 310 dab, apparently these cause drain too but touch wood it's been ok for 2 days. Not sure how strong the drain is. Ie. will the batt be flat after one night?!
If you're battery goes flat, be really careful jump starting it. I've seen so many T5 and Caddy ABS modules get blown up by very flat batteries getting jump started.
Best advise is to charge the battery up off the van or leave the jump leads on for a good few minutes to get a lump of charge in before attempting to crank.
Hopefully you won't need that advise.
The Fylde Coast No1 in-car Electrical Specialist
Cobra Autowatch JL Hertz Pheonix Gold Kenwood Steelmate Parrot
http://www.autosoundblackpool.co.uk" onclick="window.open(this.href);return false;
07973 353632[/color]
https://www.facebook.com/pages/AUTOSOUN ... 6593764755" onclick="window.open(this.href);return false;
https://www.facebook.com/groups/vwretro ... ment_reply" onclick="window.open(this.href);return false;
FREE VCDS / VAGCOM READOUT - Just call to book - QUOTE CADDY2K
MEMBER DISCOUNTS - WANT CHEAP STUFF? JUST ASK!
Re: rns510 versions
.vwbaz wrote:Been looking to upgrade to a rns510 headunit for a while, but I'm confused by all the version numbers available
RNS 510 Specifications
Touch Screen Operation
High Quality Sunlight Readable TFT display
400 mHz CPU
Standard map display, or 2D or 3D
Audio Playback in MP3 or WMA formats
SD Card Slot for MP3 data which can be copied to the hard drive (2GB Max – SDHC cards will not work)
30GB internal hard disk
DVD playback when stationary
The DVD Maps are from Navteq (Europe), Sensis (Australia)
CD Changer, IPOD Interface, Analog and DVB-T Tuners can be connected
Offroad navigation. A further innovation of the RNS 510 is a specially developed offroad navigation system. This mode makes it possible to record up to 500 route points during a journey, even in non-digitized areas. This allows the driver to find his or her way back from offroad adventures into any desert or steppe. In edit mode, the driver can modify the route as desired.
New versions of the RNS 510 are due out April 2009. No details of any changes are available.
1T0035680C (1T0 035 680 C)
3C0035680C (3C0 035 680 C) – For Start/Stop Cars
7L6035680C (7L6 035 680 C) - Touareg
1T0035680B (1T0 035 680 B)
7L6035680B (7L6 035 680 B) - Touareg
1T0035680A (1T0 035 680 A)
7L6035680A (7L6 035 680 A) - Touareg
Original Release
1T0035680 (1T0 035 680 )
It depends what year your Caddy is. If it's pre 2007 there's a good chance it will drain. Generally VCDS will tell you if you have canbus, early canbus or even k-bus. Even some early canbus require a can gateway upgrade. There's even a k-bus to canbus adaptor available.
Basically in a nutshell, think of canbus as a system of electronic modules that are controlled by one master module. When a RNS510 is introduced incompatibly, it will keep the entire canbus system awake causing heavy drain.
Re: rns510 versions
Cheers for the info, seen a few on eBay being advertised as version F and P? I guess they are just newer then, I take it they all fit?
Some sellers also advertise saying no battery drain, but surely they can't guarantee this this depending on your canbus version.
Re: rns510 versions
If your can gateway is earlier than version L you will need to change. My 2008 caddy came with a version L as it had the RCD 310. If your caddy has the RCD 300 it's likely that you may have earlier than version L.
L and newer can gateways are available on ebay for £40-£60 and really easy to change over. It's a 10 min, 1 plug swap but you then need to recode it on vag com or nothing will work.
I don't think the version of the RNS 510 makes any difference to the battery drain issue.
2008 Caddy DSG : Reflex Silver : Appearance pack : Electric pack : A/C : RNS 510 : MDI : R32 MFSW w/paddles : Golf GT seats : Touran door cards, dash and arm rest : VW Bluetooth : Highline clocks : Cruise : 17" VW Classix wheels : Side rail cover : Side strips colour coded : 140BHP remap
Also in the garage
1989 VW Golf MK1 GTI Cabriolet 20vt
2004 VW Golf MK4 R32
2014 VW Touareg R-Line 245
Fully reg VCDS (vag-com)
Re: rns510 versions
So if you already have a rns315 you can't simply upgrade to a rns510?
- dan@biali
Re: rns510 versions
You can because thats what I've just done but the bluetooth is built in on the 315 and you need a seperate bt module for the 510. Plus, if you want a DAB 510 to replace a DAB 315 you're looking at £900 if you can find one.
Re: rns510 versions
So how do you know if the Bluetooth is fitted on the 315? It just doesn't work lol
