Removing the DPF will now fail an MOT
2014 Caddy Maxi Life 2.0dsg BMT
Re: Removing the DPF will now fail an MOT
Me thinks. R32 engine for next year with sequential gas conversion
Might as well enjoy it
- Cryptwalk
Honestly makes my blood boil that does, what a bunch of jobsworths.
The technology whilst great in theory is shite in practice, how many people have dpf problems?
Just read what the minister said what an a hole bet they spent a fortune coming to that decision,they could have spent the money on OAP's or stopping the illegals that are claiming for every thing.Rant over
- Bigharty
What a GIT. Why not just code dpf regen out of ecu. Problem solved.
BIGHARTYBIGHARTY
- wiggi28
i do loads of dpf removals , only the ones where the chamber is replaced by new pipe section will be at risk as all others retain the standard look .
unless they have x-ray eyes ...........
Yea that's what I was going to add. I gutted the dpf on the t5 and at the last mot they commented on the fact it was still there and mentioned the law change
The emissions were fine and as long as it doesn't appear to be tampered with you will be fine
- tommyzooom
just hollow out your old dpf, and fit it over the straight-through pipe
- Wild Thing
Remove exhaust/downpipe Cut open remove and shut old canister where it will not be visable to tester. Mapped out. Job jobbed
Cheers Brian
1.9 TDI Caddy 150bhp so......far
Think I'm ok as I don't think I have a dpf on my caddy.....
PodgeyPerfections
- Banditbarron
- Sales Caporegime
Seriously though what MOT tester is even going to check?
My tester certainly wouldn't, and even if he did it'd still pass
On the other hand another tester i know will pass anything for £50 and for £80 he doesn't even need to see the car!
Hence my A4 has MOT done by Stevie Wonder
- wiggi28
Banditbarron wrote:Seriously though what MOT tester is even going to check?
then he needs reporting to the ministry as he is a danger to you me and every other road user and pedestrian out there .
- Cryptwalk
Yeah we all know a tester who will look away from something's but to not even give the car a once over is madness, the thing could be in a dangerous condition.
Used to take my Evo to a place and he was sensible when it came to emissions as it ran no cat etc, same will happen with DPF.
I hope so cost me 500 the pipe on the golf!
