Mileage: 59730km/37114miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 03G 906 021 AQ HW: 028 101 239 0
Component: R4 1,9l EDC 000SG 7872
Revision: --H05--- Serial number: VWZ7Z0F7101417
Coding: 0000031
Shop #: WSC 35110 377 00191
2 Faults Found:
013112 - Control Circuit for Glow Plug Controller 1: Electrical Malfunction
P3338 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 59427 km
Time Indication: 0
Date: 2000.00.00
Time: 20:22:17
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 11000100
Temperature: 78.3∞C
Bin. Bits: 01010000
005377 - Fuel Pump Relay (J17): Short to Ground
P1501 - 000 - - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 59427 km
Time Indication: 0
Date: 2000.00.00
Time: 20:22:17
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 11000100
(no units): 0.0
Bin. Bits: 00000000
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017106
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000006118235
Coding: 00884F030004100000000000000000000008FB075C
Shop #: WSC 35110 377 08192
Part No: 2K2 955 119 C
Component: Wischer 310706 020 0501
Coding: 00038805
Shop #: WSC 35110
2 Faults Found:
00906 - Horn (H1)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 52
Mileage: 59252 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.70 V
OFF
ON
OFF
OFF
OFF
00834 - Signal for Activation of Heated Rear Window
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 53
Mileage: 59427 km
Time Indication: 0
Freeze Frame:
ON
Voltage: 12.35 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 09 AIRBAG VW52 023 2400
Revision: 04023000 Serial number: 0037TD0BC1B1
Coding: 0012345
Address 16: Steering wheel Labels: 1K0-953-549.lbl
Part No SW: 1K0 953 549 BB HW: 1K0 953 549 BB
Component: Lenks‰ulenmodul 035 0070
Coding: 0000002
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 2K0 920 943 A HW: 2K0 920 943 A
Component: KOMBIINSTRUMENT VDD 1612
Revision: V0003000 Serial number: VWZ7Z0F7101417
Coding: 0017401
Shop #: WSC 00330 210 82810
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H04 0010
Revision: H04 02 Serial number: 16060602000782
Coding: 1D0F014007007401
1 Fault Found:
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 31
Reset counter: 53
Mileage: 59367 km
Time Indication: 0
Date: 2000.00.00
Time: 15:25:54
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VDD 1612
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0930
Coding: 0000560
1 Fault Found:
01330 - Central Control Module for Central Convenience (J393)
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 008A0C087F2D0F0FC85A205010C0
Component: Sounder No Answer
Component: NGS n.mounted
Component: IRUE n.mounted
1 Fault Found:
01134 - Alarm Horn (H12)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000560
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 R
Component: Radio BVX 020 0032
Coding: 0020200
End ---------------------------------------------------------------------
Vag com Log file.... some weird finds
- Grizzle
1.9 TDI PD, Custom Code remap 156bhp & 239lbft , rear tints, 16" Golf GT Alloys, VW Mudflaps, H&R Springs, Cruise Control, Koni Sport Dampers, GT Badge, MK5 Golf GTI brakes all round.
- hedge
Re: Vag com Log file.... some weird finds
Your battery has been disconnected! save and clear errors! see what comes back,
I would say from all of those errors the glow plug one would worry, me look it up on http://wiki.ross-tech.com/index.php/Main_Page when its back up
Intermittent fault can mostly be taken with a pinch of salt i.e note clear and keep a eye on it
