What engine cover will fit 2.0 sdi?
Thurlow32
Post by Thurlow32 »
I've seen a few people adding engine covers and I've taken a liking just wondering if anyone knows what engine cover will fit my 07 2.0 sdi?
Decinick
Re: What engine cover will fit 2.0 sdi?
Post by Decinick »
I think it depends on what your engine code is.
Thurlow32
Post by Thurlow32 »
You know how to find out mate?
Decinick
Post by Decinick »
Don't know if it's in the van, presume it is somewhere but mine is on my log book;
P5. Engine number BST XXXXXX
It's the three letters you need, in my case (59 plate 2.0litre sdi) it's BST
Hope this helps.
Si the Chippy
Post by Si the Chippy »
Pop in to your nearest TPS and give them your registration number and they will be able to find the correct engine cover and order it for you.They do cash sales with an element of discount,will work out cheaper than buying it from VW.You will need the engine cover and probably the two front mounting connections that screw into your engine block.Check the parts diagram at TPS and see what you have/have not got on your block and order accordingly.Will be around the £100ish mark (ouch),cheers Si. :)
Thurlow32
Post by Thurlow32 »
Cheers lads :)
caddymitch
Post by caddymitch »
Mk5 golf sdi cover is same. I have 1 on mine. You will just have to purchase a couple of bits from TPS
