buying caddy tdi and common problems
hi, iv just sold my t4 now looking to get a mk3 caddy tdi
through other peopples experiences i was wondering what the common problems are?
and what to look out for when viewing one?
also do they rust?
thanks in advance
Jaz
also do they rust?
thanks in advance
Jaz
- chezzy71
Re: buying caddy tdi and common problems
ive never seen rust on a 2k...
viewtopic.php?f=13&t=10101
Tbh ive never actually come across a caddy 2k thats got issues. They a lot like Touran's as ive got both and they pretty reliable. Only issue ive had was the dpf filter on my Touran and that was it.
Code: Select all
image_zps56120b62
One thing to look out for - Make sure there's no ABS/Taction control lights on the dash. This could mean the ABS module is knackered which isn't cheap to repair.
Forgot to mention my touran needed an abs pump. They close to £1k!Royd wrote:One thing to look out for - Make sure there's no ABS/Taction control lights on the dash. This could mean the ABS module is knackered which isn't cheap to repair.
Code: Select all
image_zps56120b62
VW are replacing the mk60 pump for free regardless of age. Its a safety thing.
So if i was to take my 57 plate touran to VW they would replace it free of charge??Doc wrote:VW are replacing the mk60 pump for free regardless of age. Its a safety thing.
Code: Select all
image_zps56120b62
If its the mk60 pressure switch fault, yea.
How can i check if it is that?!Doc wrote:If its the mk60 pressure switch fault, yea.
Code: Select all
image_zps56120b62
VCDS scan is best. It will confirm the fault also.
Ok cool. Thx palDoc wrote:VCDS scan is best. It will confirm the fault also.
Code: Select all
image_zps56120b62
- Stuvw
Check the cambelt and water pump has been changed if milage is above 80k,and like alot of vw vans the electrics can be hit and miss.as long as everything works as it should,you should be ok.
You know the funny thing is that the abs light is on in the Touran but its had a new clutch fitted 1month ago along side a cambelt kit and water pump. Ive had the rear light bulb light come on and then had a warning light display a message. Ive read that a blown tail light can cause electrical problems?!? How true is that. After changing the bulb all was ok for 2 weeks then it happened again, ive ignored it for a while and the issue dissapeared. How bizareStuvw wrote:Check the cambelt and water pump has been changed if milage is above 80k,and like alot of vw vans the electrics can be hit and miss.as long as everything works as it should,you should be ok.
Code: Select all
image_zps56120b62
- Stuvw
Most random problems occure from water or damp in the electrical system so maybe after a while it dryed out and jobs a good one.T5's and Caddy's (more T5's from what I've seen) suffer from water building up (for several reasons,leaks or jet washing the load bed etc)in the cab and foot well which eventually interferes or rots wires and connectors.wherever water comes into the van it settles in the cab somewhere.
Talking about it i have noticed the rear lamp does have damp build up inside like steamed up. Should i just seal it with silicone?!?
Code: Select all
image_zps56120b62
