What type airlift shall I get ?
Price ranges including fitting?
Also I'm a gardener and need my back full of tools neatly away not like you see all over the van, but I need the tank hidden away and boxed if possible; I also got told today I possibly could have it under my seats with a bit of mods to it, please could you help. Need air lift in my life!
Airlift on caddy?
- dan@biali
Re: Airlift on caddy?
No easy answer I'm afraid. Front mk5/6 golf will fit straight on so depends on your budget. Airlift Slam or Performance series are top of the range. Rear will need some engineering solution. Most use a 4 link with watts linkage and again, Airlift bags. With digital management your looking at £4000 I reckon. Obviously a lot cheaper if you can do all the work yourself.
- Stuvw
ive gone for airlift slam mk5 front struts and rear bags and v2 management.I run it everyday so ive gone for a A frame setup on the rear.As stated depends on your budget to what you can get.I bought all my stuff from radioworld for around 2k then a mate did the rear axle for cheap so mine would be one of the cheaper airlift caddys built
