Touran seats fitted!!!! Seat belts
Posted: Mon May 19, 2014 10:22 pm
by Mashona
I've got my Touran middle seats fitted now after some welding and drilling......
The space for the seat belts in the pillar is filled by the door slide rail,
I'm wondering if you can modify this to take the touran belts or do I need maxi seat belts?
Thanks,
Phil.
Re: Touran seats fitted!!!! Seat belts
Posted: Tue May 20, 2014 12:52 am
by Mashona
Anyone!!!!
Posted: Fri May 23, 2014 10:01 pm
by drw42
Mashona wrote:I've got my Touran middle seats fitted now after some welding and drilling......
Thanks,
Phil.
Not sure what you are asking but I think I may have had the problem. On the offside I fitted the inertia real behind the pillar.
On the near side there is a big lump in the way where there appears to be a inside cover for the sliding door rail.
I thought about trying to cut it out or beat it flat but wasn't sure if there would be room even then. You can see I have given it a bit of a whack. I'm sorry to say I bottled it as it isn't a very old van and didn't want to cock it up. However you can weld the spreader plate to the outside and simply fit the inertia reel sticking out. I will put some sort of cover over it or box it in when I get round to it.
Also someone said they had to get the spreader plates ground off because they have a raise edge. I just squashed them flat in a vice and used the whole thing
Hope that is some help since there were no other answers Best of luck Woody
Posted: Fri May 23, 2014 10:52 pm
by Mashona
Cheers Woody,
Ive got 2 sliding doors therefore both belts need to be mounted sitting inwards.
Thanks for the pictures.
Posted: Sat May 24, 2014 11:15 am
by bigmac
I've got a factory built maxi Kombi van and my seat belts look like they bolt onto the hole where yours is, but mine is on the outside with a plastic cover over it which clips into the slots around the opening
Posted: Sun May 25, 2014 1:11 pm
by Postman_bat
All rear caddy seatbelts r sticking out mate hense the big plastic covers over them
Then if u fit these trims they cover the reel
Posted: Sun May 25, 2014 2:29 pm
by Wind Welder
Hi,
Yep reels are on the outside. My maxi kombi has them that way round anyway.
Cheers Trev.
Posted: Thu May 09, 2019 8:58 am
by Butch 1980
Do you have any pictures on how the seat belt is attached to the floor please ?
Posted: Fri May 15, 2020 1:58 pm
by Woj_88
Could I jump in too and ask if there are any photos of how everyone has attached the seatbelt to the floor too? Thanks!
Posted: Sun May 17, 2020 12:58 pm
by Woj_88
Do you have a part number for the access panel for the jack goes, I have the exact same panel minus the access cover
