HELP OIL OVER MAX - VAG SUSPECT FUEL CONTAMINATION
Posted: Sat May 31, 2014 12:47 pm
by Mack Caddy
Guys I need some urgent advice
has anyone had a problem like this
caddy is running fine, just been in as the service light was on , having been set to 1 year not 2 , so VAG reset , but advise that my oil is over the recommended level and they think its contaminated with fuel
the vans done 1250 miles since the oil was changed by VAG (12 months ago)
vans mileage is 88k
there is a slight weep of oil at the tandem fuel pump , could this be the problem ?
or is it as suggested internal seals failing ?
they say that I need to have an oil change than monitor it and then strip engine to rectify the fault if it persists - anything from £250 to a new engine :( :(
all info appreciated as I don't even want to drive it and make it worse
Re: HELP OIL OVER MAX - VAG SUSPECT FUEL CONTAMINATION
Posted: Sat May 31, 2014 4:00 pm
by Springer Mad
Well I would certainly get a sample of oil analyzed before you allow the garage to do anything, That will tell you if there is diesel in the fuel. Although you might even be able to smell it in the oil when they take the sample??
And if it was my van I don't think I would be driving it either. U could drain the oil once the sample has been taken and refill with fresh oil but I feel that's a waste of time and money.
As regards to next step I would wait until you get the results.
Posted: Sun Jun 01, 2014 8:48 am
by cactusgreen
I've used Blackstone Labs for years.......http://www.Blackstone-labs.com doesn't take very long and they really know their stuff.......I've done oil and atf fluids
Posted: Wed Apr 08, 2015 1:35 pm
by Dubjon
I've now experienced this today - loads of smoke and the engine accelerating itself.
Took it to JC Vehicle Services in Torbay who drained 9 litres of oil/diesel from the engine - there should only be 4 litres :?
He's changed the oil today, but is booked in for a few weeks time when he's next free for a full investigation.
To say i'm gutted is an understatement :( I'm more or less stuck without transport until May, as I sold my old but perfectly working Caddy 5 days ago :cry:
Has anyone else experienced this?
Posted: Wed Apr 08, 2015 1:59 pm
by alarmfitter
It could be the injector seals or it could be the head worn where the injectors sit
Posted: Wed Apr 08, 2015 2:02 pm
by Dubjon
Sounds expensive either way :cry:
Have you had that problem yourself?
Posted: Wed Apr 08, 2015 2:12 pm
by alarmfitter
I used to be be manager of a big engine reconditioning company we saw a few but it's common on the t5 2.5 axd engine
Posted: Wed Apr 08, 2015 3:30 pm
by Dubjon
Ah ok, this is on a SDI engine
Posted: Wed Apr 08, 2015 3:31 pm
by alarmfitter
Same setup
Posted: Wed Apr 08, 2015 3:59 pm
by Dubjon
ok
To be honest its put me off the caddy now, so I might sell it with the issue described in the ad so I'm not duping anyone...
Posted: Thu Apr 09, 2015 8:58 am
by Dubjon
Anyone know of any reputable VW garages in Torbay area?
Dont want to use JustVanz, and is already booked in at JC Vehicle services but the soonest he could get me in is 13th May!
Want to take it to someone who knows what theyre doing with it and has worked with these engines before.
Posted: Tue Apr 14, 2015 3:57 pm
by Dubjon
Anyone used other VW garages in Torquay area?
Posted: Sat Apr 18, 2015 11:02 pm
by GPG
alarmfitter wrote:I used to be be manager of a big engine reconditioning company we saw a few but it's common on the t5 2.5 axd engine
What was the issue/fix on them engines?
Posted: Wed Apr 29, 2015 12:18 pm
by Dubjon
Anybody else with experience of this?
Posted: Wed Jun 03, 2015 4:51 pm
by Dubjon
For info, after replacing number 2 injector and seals, and also number one injector seal, also injector loom, all problems were sorted.
