Cooling fans on constantly
Chrisg1980
Post by Chrisg1980 » Sun Jan 04, 2015 10:26 am
Now then fellas, just bought an 07 TDi and the radiator fans seem to be running constantly. Anyone got any ideas as to what it could be or had this fault themselves?
Cheers, Chris
2007 1.9tdi, Mk5 GTi front seats, Touran front end, Removed Bulkhead, Sound deadened, insulated, Carpet lined, VMaxx coilovers, colour coded rear bumper, Touran front carpets, 3SDM 0.04's, Alpine 136BT, Touran centre console w/armrest, MK6 GTD flat bottom steering wheel, Reflex Caddy Siderail cover, German Driverside(UK Passenger side) wingmirror...
Still to come - Focal speakers
pounder770
Re: Cooling fans on constantly
Post by pounder770 » Sun Jan 04, 2015 11:04 am
I have had this problem before...
Has the outside temp.display gone too?
The wire to the sensor in the front bumper breaks...the engine then has no outside air temp,so that makes it activate the fans.
Common fault.
Chrisg1980
Post by Chrisg1980 » Sun Jan 04, 2015 7:35 pm
Hello mate, thanks for the reply. The temp gauge is working fine. Hmmmmmm, the plot thickens
Motosparkz
Post by Motosparkz » Sun Jan 04, 2015 11:08 pm
On a lot of vag stuff, if it has the control module bolted to the rad, these can fail. First thing is get it code read with live data to see what it thinks is going on. Do you know anyone with VCDS?
I am just looking at getting a maxi, so can't tell you any more than that unfortunately as not had a lot to do with them, yet!! :-)
pounder770
Post by pounder770 » Sun Jan 04, 2015 11:21 pm
Outside temp... Not engine temp... Just to be clear :-)
Chrisg1980
Post by Chrisg1980 » Mon Jan 05, 2015 11:27 pm
Yeah the outside temp is defo working pal.
Will get the code read tomorrow and leave some results here
Chrisg1980
Post by Chrisg1980 » Wed Jan 07, 2015 5:28 pm
Got this sorted gents, its the Aircon Pressure Switch thats at fault. £30 fix and its all done.
Good news for anyone else with the same fault.
pounder770
Post by pounder770 » Wed Jan 07, 2015 9:28 pm
Nice one!!
phanson
Post by phanson » Thu Jan 08, 2015 9:39 am
Good info!
Sturu
Post by Sturu » Sat Jun 06, 2015 6:28 pm
Thanks pounder770, yours worked for me!
Who is online
Users browsing this forum: No registered users and 2 guests
