Caddy 6 speed conversion
Chrisstephen84
Post by Chrisstephen84 »
Hi there I'm jus new to this site as jus recently purchased a caddy van, the gearbox doesn't feel great and was looking to do the 6 speed conversion from a mk4 golf 130 bhp, was jus wondering if anyone can help me out, on what needs to be changed and if there's any complications with it, any help would be appreciated.
paul4314
Re: Caddy 6 speed conversion
Post by paul4314 »
u would need to change
flywheel and clutch
starter motor and wireing plug
u need 6 speed drive shafts and fit caddy cv joints on them
gearbox mount bracket thats on the 6 speed box
and the bleed valve from the 6 speed aswell
and all bellhousing bolts
gear cable mounts that bolt to gearbox
and you will need the 2 quick release gear linkage ends that fit to the selector shafts
what engine do u have in your caddy and what gearbox u looking at needs to be an 02m model gearbox to fit to a bls caddy engine
make sure you read new members section fully so u can gain access to full site t see more on this topic
Springer Mad
Post by Springer Mad »
You won't be sorry doing it, I had mine done few months back and its changed the whole driving experience for the better, much more fun with the 6 gears.
paul4314
Post by paul4314 »
100% on that love mine i have the drw long ration sit at 90 doing 32mpg :mrgreen:
but it makes such a difference and for a nicer drive aswell
Springer Mad
Me too with the Drw box, the only thing I miss is being able to trickle along in traffic like I could with the 5 speed, find first can be slightly too quick sometimes. That and not having cruise control in 6th is a pain.
Chrisstephen84
Mines the now is a caddy with a bls engine in it, the gearbox is from a mk4 130 bhp asz I'm guessing that this is the 02m gearbox, what drive shafts and c.v joints are used, as the mark 4 c.v joints have a but on the end and caddy has a bolt on them? Does caddy c.v joints fit on the mk4 driveshafts?
Chrisstephen84
Jus re read ur post there n seen that uve told me bout driveshafts with caddy c.v joints, sorry mate, thanks for the info,
shoneduart
Post by shoneduart »
I have a 2014 Caddy Trendline 1.6 tdi 75kw 5 spd. Is it worth/possible to convert it to a 6speed trans?
thanks!
Gafn95
Post by Gafn95 »
Hi everyone, I’ve just put the ASZ lump in my caddy with a BMM 2.0 turbo and I’m having trouble with the driveshafts now what has people used when doing this conversion to the 6 speed 02M?
deanonutter031011
Post by deanonutter031011 »
need the shafts out of a mk5 golf mate
Cliffy
Post by Cliffy »
deanonutter031011 wrote: Sat Apr 04, 2020 5:49 pm need the shafts out of a mk5 golf mate
I have an O2Q gearbox, would the 2.0 tdi MK5 golf shafts fit or will I have to swap the CV joint over?
R32josh
Post by R32josh »
Dpes anyone have a rough cost of getting all the parts, total?
59 white SWB 1.9tdi
New, it's likely no longer possible to buy a gearbox for this.
Used go for anything from £250 to £600 depending on condition/mileage/warranty/sellers greed.
If you can do the labor yourself and your original gearbox is working and sellable, you can do the whole job for not much money once you sell your original box, starter, drive shafts etc..
Iv had Darkside email me all costings for this.
Manual 6 speed gearbox conversion (2 options):
Full 6 speed gearbox conversion £500+ VAT (Includes everything you need)
Sachs 02Q DMF complete clutch kit from £650+ VAT (up to 200 BHP)
https://www.darksidedevelopments.co.uk/ ... tform.html
Sachs 02Q Race kit complete from £895+ VAT (200-300 BHP and above)
Fitting from £250+ VAT -
We have a lot of 02Q 6 speed modifications (Short shifter, and strengthening mods) for more information on those please contact us.
This is for my van mind you, but probably good for a ball park figure
dan@biali
Post by dan@biali »
For reference, it appears both 02M and 02Q 6 speed boxes are available as I just had a glance at the parts database and neither show as discontinued. The price new is £2800 :shock:
