broken new van already!!!!
phil220
Post by phil220 » Tue Mar 10, 2015 9:45 pm
so went a bit wild with the power washer and washed the engine not too much to be honest. so anyway it cut out and its very very hard to start and in limp mode and esp light and engine light is on. throwing code P0652. an ideas anybody??
Re: broken new van already!!!!
Post by Doc » Tue Mar 10, 2015 10:02 pm
2013 1.6TDI, Edition 30 18" BBS Peschara, Caddy4 rear lights, 2016 Polo GTI (mk7 style) steering wheel, TRC front splitter, Relentless Tuning front coilovers, Audi A6 S-Line front seats, mk6 GTI Front & rear Brakes, 3D Colour Premium dash cluster, Caddy life arm rest, Motexion bulkhead, 2016 MIB head unit
dan@biali
Post by dan@biali » Tue Mar 10, 2015 10:54 pm
Did you protect any of the electrics before power washing?
phil220
Post by phil220 » Thu Mar 12, 2015 1:41 am
dan@biali wrote:Did you protect any of the electrics before power washing?
No have washed plenty of engines before with no issue till now
paul4314
Post by paul4314 » Fri Mar 13, 2015 7:58 am
did u solve this best thing i recommend is pull all the plugs of and wd40 them and reconnect i have done many engine washes never had this issue so can either say u accidently got to close to a connection without noticeing or some one has lost/removed the water proof seals from a plug somewhere is that the only code u are getting up as this is alll i got from ross tech site
http://wiki.ross-tech.com/wiki/index.ph ... 652/001618
are u using vcds to get codes
phil220
Post by phil220 » Sat Mar 14, 2015 11:31 pm
Have tried this checked all connections they all seem fine no signs of water in any of them at all. . Have ecu out now send it off to have that checked.
V111FEN
Post by V111FEN » Mon May 25, 2015 12:31 am
Try checking the wiring loom between the engine and the chassis leg, common problem!!
Adam87
Post by Adam87 » Wed May 27, 2015 9:56 pm
Mine did same thing when washed, wiring loom that crosses over the gearbox had worn through!
Who is online
Users browsing this forum: Avalanche, scoobxs and 1 guest
