Handbrake warning light
acherrystone
Post by acherrystone » Sat Apr 11, 2015 3:42 pm
Just after I start up and drive away, my handbrake warning light flashes for a short while and I get three loud pings.
The light then goes out but returns every few minutes, with the three pings, before stopping altogether.
But sometimes it doesn't do either flashing or pinging.
I am 100% certain that the handbrake is off.
Can anyone please advise me?
Thanks.
cherry :)
Girls do drive vans too. ;)
stan-the-man
Post by stan-the-man » Sat Apr 11, 2015 4:30 pm
The handbrake switch is located under the lever. It's probably come loose or faulty I would imagine.
You will have to remove the console to check or peek through the gaps under
EDIT
It will look something like this:
(Pic found on the net)
acherrystone
Re: Handbrake warning light
Post by acherrystone » Sat Apr 11, 2015 4:47 pm
It really is that simple?
I have been worried sick, I thought it was going to be indicative of a new engine.
I could kiss you. ;)
cherry :)
stan-the-man
Post by stan-the-man » Sat Apr 11, 2015 5:30 pm
The switch makes the light go on/off etc
Perhaps it's just slightly displaced as if it was completely off the light would stay all the time.
acherrystone
Post by acherrystone » Sun Apr 19, 2015 8:22 am
I got the switch out ok. I have oiled it and the contacts and it is still messing about, so I have ordered a replacement.
I didn't need to remove the console. I took out the drivers seat, and the two bolts at the back of the console, then held it up, and wiggled out the switch with a screwdriver.
Hopefully, replacement will be a reverse. :)
cherry :)
acherrystone
Post by acherrystone » Tue Apr 21, 2015 6:53 pm
I now have got a replacement switch and I am no better off.
Any other option or cause of this flashing warning light and warning beeps?
cherry :)
stan-the-man
Post by stan-the-man » Tue Apr 21, 2015 7:41 pm
Oh feck!
Is it a fl caddy?
The switch is controlling the light on dash. One wire is ground the other goes into clocks. Have you done any modifications prior to the first occurance?
Unless the wire is clipped somewhere??
The wire for connection in instrument cluster is T32/25 (brown/yellow)
I'm sorry I can't be any more help.
tommyzooom
Post by tommyzooom » Tue Apr 21, 2015 9:33 pm
I can't remember, does this light also indicate low brake fluid too?
acherrystone
Post by acherrystone » Wed Apr 22, 2015 10:13 pm
tommyzooom wrote:I can't remember, does this light also indicate low brake fluid too?
Yes, it does, and the light has now gone out, after I topped it up.....
I now have to check out the brake pads, hopefully, they are well worn. That is a cheaper repair than finding and repairing a leak.
On the positive side, both brake and clutch pedal feel firm.
cherry :)
Who is online
Users browsing this forum: dutchy, JedW, sharpy52 and 2 guests
