Caddy tdi crank shaft sensor replaced but still won't start
Logan1664
Post by Logan1664 » Sun Apr 12, 2015 10:04 pm
So my 06 tdi (barn door) caddy was in limp mode with the glow plug light on, engine oil light on and with no rev counter..... It was also getting harder and harder to get it started & in jan keep it running when started from cold - So I left her parked until I had time...
I had the fault codes read on sat & it said faulty crank sensor - which made sense on the failure to start and rev counter issue!!
So I've replaced the sensor - which was a serious pain & the glow plugs & now my caddy still won't start, and I if I get it started with a little easy start - I still have no rev counter, glow plug light is still on & engine oil light
WTF people - help
Funbagjuggler
Re: Caddy tdi crank shaft sensor replaced but still won't st
Post by Funbagjuggler » Mon May 04, 2015 10:36 pm
Check cam timing hasn't jumped a tooth.
Just had this with one at work....
Said cam sensor no reading, but was just out of sink with crank timing....
Russie
Post by Russie » Fri May 08, 2015 8:45 pm
Agree. Could have stripped a few teeth off the belt and put the timing out. Seen that before. No more easy start until you've checked it!
IF IT AIN'T BROKE, BREAK IT
Euro Technika
Post by Euro Technika » Sun May 10, 2015 10:34 pm
Crank sensor will show faults even if there good. This happens when the engine is cranked over many times without starting
Freeman506
Post by Freeman506 » Tue May 12, 2015 7:33 pm
I had this problem, changed the sensor and it was still the same. So took it back to my geezer and he looked at the wiring and found that it was not the best, so he fixed the wiring going to the crank shaft sensor and she hasn't been a problem since. So i would say just check the wiring as well (unlike what i did) and if not, what the others said as well dude.
V111FEN
Post by V111FEN » Mon May 25, 2015 12:12 am
Try checking the wiring loom between the engine and chassis leg there pron to braking wires there.
Who is online
Users browsing this forum: No registered users and 3 guests
