Drilling seat bases
PSBS
Drilling seat bases
Post by PSBS » Thu May 07, 2015 3:58 pm
Hi all. Purchased some mk5 gt seats for the caddy today.
I am determined to use the Caddy bases as I'm a tall guy and also I'm used to sitting lower... I find it much more natural (for myself)
I can see the one big pin on the one rail of each seat, which needs cutting off... Which I have done.
So now drilling. A hole on each side of each seat, I've heard.
However. Are the holes to be drilled at the front, using the standard rear bolt holes.
Or
Drilled at the back, using standard front holes?
Also I assume you drill the bases, as opposed to the sliding rail itself.
Any help appreciated as ever. Pics if possible of the mounting!
Scott :)
Gibbo
Re: Drilling seat bases
Post by Gibbo » Thu May 07, 2015 9:58 pm
I have touran bases myself but I'm pretty sure you have to fit the front holes with original bolts then drill the back of each rail !
PSBS
Post by PSBS » Sun May 10, 2015 7:51 pm
So this happened at the weekend. Drilling was a doddle!
For rear bolts, drill fronts about an inch forward than the existing holes.
M8 bolts, washers both sides, nylock nuts. Done
Seats had only done 40k so flawless. Massive improvement over standard in both comfort & road holding! I went about different & used the rear headrests, so nice on your head/neck not to mention look a lot better!
Oh and the best part is I got front & rears for £60...
I sold the rears for £40 cash... Selling the caddys to a mate for £20...
Free straight swap :D
Gibbo
Post by Gibbo » Sun May 10, 2015 8:00 pm
Good work
Strath25
Post by Strath25 » Sun May 10, 2015 8:54 pm
Looks spot on and a stonking deal, bet they feel so much comfier knowing they were basically free :-)
Who is online
Users browsing this forum: Bing [Bot], DJOHALL, Google [Bot] and 4 guests
