Post by McGeeee » Fri May 08, 2015 2:56 pm
Im wiring in a sub and was wondering if theres any points i can feed the live through to get to the battery? Thanks in advance
Re: Subwoofer
Post by mostlysimon » Fri May 08, 2015 5:24 pm
There's a grommet just under the 'glove box', you'll have to undo the two big retaining plastic screws and pull the thin foam down in order to access it. Easiest method is to push a screwdriver through the grommet to create a little hole then tape your cable to a piece of welding rod (or something like that) to force it through.
Who is online
Users browsing this forum: Bing [Bot], mark1a and 1 guest
