Subwoofer
Posted: Fri May 08, 2015 3:56 pm
by McGeeee
Im wiring in a sub and was wondering if theres any points i can feed the live through to get to the battery? Thanks in advance
Re: Subwoofer
Posted: Fri May 08, 2015 6:24 pm
by mostlysimon
There's a grommet just under the 'glove box', you'll have to undo the two big retaining plastic screws and pull the thin foam down in order to access it. Easiest method is to push a screwdriver through the grommet to create a little hole then tape your cable to a piece of welding rod (or something like that) to force it through.
