Central locking problem HELP!!!!!!
d5 kny
Post by d5 kny » Fri May 15, 2015 6:20 pm
Hi folks looking for some advice
My caddy 59plate won't open or lock using the fob so first thing I tried was change the battery in fob but didn't work so checked fuses they are all OK and disconnected main battery for 10mins but still not working. If you put key in door it unlocks and locks doors
So is there a receiver or module that picks up signal from fob
Darren
gprent
Re: Central locking problem HELP!!!!!!
Post by gprent » Sat May 16, 2015 10:35 am
hi there,
its quite possible that the remote has lost it's sync. this can happen if the fob was operated to many times when out of range.
there is a module that receives a signal and its called conveiniance module, depending on the setup inside there, it may be possible to do a
manual re sync. but if it doesn't work then your going to have to do it with software.
gareth
kirade
Post by kirade » Sat May 16, 2015 12:35 pm
Mike
d5 kny
Post by d5 kny » Sat May 16, 2015 6:14 pm
Hi Gareth when you say using software do you mean vagcom if so tried it last night but still not working
d5 kny
Post by d5 kny » Sat May 16, 2015 6:15 pm
Thanks for the link buddy but the one problem I have is I have only got one key :cry:
d5 kny
Post by d5 kny » Sat May 16, 2015 6:19 pm
Here's what I got when I ran a system check earlier but what's weird is the central locking all work when pressing the button on the door card
Euro Technika
Post by Euro Technika » Sun May 17, 2015 10:28 am
Wouldn't be concerned with those faults ATM only intermittent faults. Thermal protection means they have been operated continuously for to long most likely from the button on the door.
If you got vcds you can adapt transponder.
Go into channel 46 then select adaption. Should find it in there.
Who is online
Users browsing this forum: dutchy, JedW, sharpy52 and 2 guests
