Electrical gremlins
mkvanman
Electrical gremlins
Post by mkvanman » Tue May 19, 2015 2:08 am
Im having a problem with overnight brake lights the vans parked up still but on 3 occasions now the brake lights have come on I have just got home & they are on again & its draining the battery.Any ideas I will have to look at the new carpets maybe they are touching something
stan-the-man
Electrical grellins
Post by stan-the-man » Tue May 19, 2015 5:22 am
More likely the brake light switch gone faulty. It happened to my golf before and has been one of the common issues with VWs.
Rs4-cab
Re: Electrical grellins
Post by Rs4-cab » Tue May 19, 2015 5:52 am
Get a genuine switch tho from Tps or vw not a gsf copy there crap !
1.9TDi (104) Full elects and a/c, Mfsw Steering wheel, GOlf r line front Brakes, Sat nav with intergrated phone kit, Colour Premium dash cluster, OE Touran xenon headlights, Appearance pack front bumper, Caddy life arm rest. Remaped, egr delete, hybrid turbo Golf gtd front seats.19" taledaga alloys. 2016 rear lights.
To come: R32 exhaust, Carpeted load area, etc. etc.
Euro Technika
Post by Euro Technika » Tue May 19, 2015 9:40 am
Replace the switch. Heard of that issue once before a customers battery kept draining overnight tech carried out all tests couldn't find a thing wrong
Then While it was sitting in the workshop locked up bang out of nowhere brake lights turned on.
Lucky find!!!
mkvanman
Re: Electrical gremlins
Post by mkvanman » Thu May 21, 2015 8:56 am
Replaced switch now just gotta charge battery.Part number for switch from VW 1K2-945-511- -RDW cost £10.87 plus vat
mkvanman
Post by mkvanman » Fri May 22, 2015 11:43 pm
Fitted switch nothing depress pedal nowt put old one back on & have permanent brake lights WTF
Strath25
Post by Strath25 » Sat May 23, 2015 4:57 am
mkvanman wrote:Fitted switch nothing depress pedal nowt put old one back on & have permanent brake lights WTF
Have u fitted it correctly, once old one removed, press pedal right down, insert new switch but don't turn it until u let pedal back up, also make sure it's fully turned clockwise
rsjohn
Post by rsjohn » Sat May 23, 2015 6:43 am
May also need to delete code from ecu.
mkvanman
Post by mkvanman » Sat May 23, 2015 9:55 am
Will try this afternoon I got the switch using reg from Vw but looks slightly different.
mkvanman
Post by mkvanman » Tue May 26, 2015 2:53 pm
Thanks to Doc told me how it should go it was my fault 30 secs job done.
Who is online
Users browsing this forum: No registered users and 1 guest
