What is the neatest way of holding and charging your iphone?
18ME
Post by 18ME » Thu Jun 04, 2015 1:07 pm
I want to be able to see my phone whilst in the van and also be able to charge at the same time, the only connections I can see are the 12V cig lighter socket and the jack point under the sat nav screen, what have people done?
Re: What is the neatest way of holding and charging your iph
Post by Doc » Thu Jun 04, 2015 4:03 pm
Have a look at the Brodit range of holders, they do basic, passive and active versions and are great quality.
2013 1.6TDI, Edition 30 18" BBS Peschara, Caddy4 rear lights, 2016 Polo GTI (mk7 style) steering wheel, TRC front splitter, Relentless Tuning front coilovers, Audi A6 S-Line front seats, mk6 GTI Front & rear Brakes, 3D Colour Premium dash cluster, Caddy life arm rest, Motexion bulkhead, 2016 MIB head unit
Mr. P
Post by Mr. P » Thu Jun 04, 2015 4:33 pm
PodgeyPerfections
dubvan
Post by dubvan » Thu Jun 04, 2015 8:49 pm
Another vote for brodit. Had passive and active holders and they are fab'.
Timmyd
Post by Timmyd » Thu Jun 04, 2015 9:12 pm
I tried various options and found tetrax magnets by far the best option for me.
DynamoTightstar
Post by DynamoTightstar » Thu Jun 04, 2015 9:30 pm
I use a Spider Grip that clips on the air vent. Held my iPhone 4s no probs and now my 6 without issue.
Its all about the corners. Anyone can go fast in a straight line.
18ME
Post by 18ME » Fri Jun 05, 2015 12:27 pm
Thanks for all the suggestions :)
The Brodit seem pricey for what I need but probably neater than most and not really a fan of the vent holders. I've had a look at the ones on ebay and may go for one of these http://www.ebay.co.uk/itm/Excelvan-Univ ... 259a1370a4 but quite like the magnet idea, not seen these before. Are they really strong enough to hold the phone when you hit bumps in the road? not sure where I'd put it though as it obviously sits flat against the surface you place it on, where's yours?
Postman_bat
Post by Postman_bat » Fri Jun 05, 2015 5:44 pm
I run a tetrax magnet holder on the dash vent above stereo works a treat
Sturu
Post by Sturu » Sat Jun 06, 2015 2:23 pm
I just bought an iOttie iTap magnet holder.
It holds the phone really well. The weakest point will be how well my vents stay in place. They're doing fine at the moment.
Likely not as good as the Brodies (and no built-in charging), but really convenient. Just put your phone near it and it snaps on solid. It works great with my thinner plastic case on the iPhone 5c, but it didn't work through the folded-back book-style case I also have. You get two metal plates as options. Use a small circular one if you want to stick it on the outside of the case, or stick a larger one to the phone itself, under the case. I haven't stuck mine - it's just held against the phone by the case.
Worth a look.
Stuart
MMM1978
Engine size/power: 2.0 CR TDI (140bhp)
Post by MMM1978 » Sun Jun 07, 2015 3:01 pm
Brodit!
Change the phone side when you change phone, and change vehicle side when you change vehicle! Brilliant, proper holders designed specifically for your handset and car.
MMM1978
Post by MMM1978 » Sun Jun 07, 2015 3:02 pm
Tetrax are OK, if you don't mind having a magnet stuck permanently to your phone... Had one for a while, myself.
Postman_bat
Post by Postman_bat » Sun Jun 07, 2015 10:23 pm
My phones always in. Case so stick the magnet to that and then re stick it new case when I change lol
Timmyd
Post by Timmyd » Mon Jun 08, 2015 8:07 pm
Postman_bat
Post by Postman_bat » Mon Jun 08, 2015 8:21 pm
Here's the one I got
Just remove it and fit it in the other car when needed
http://www.ebay.co.uk/itm/NEW-TETRAX-GE ... 56752c5fa2
Who is online
Users browsing this forum: No registered users and 1 guest
