LSZ caddy
- cadmad
- cadmad
Re: LSZ caddy
So I just bought this for the caddy.
- cadmad
Re: LSZ caddy
Need some one near hand to do coding.
- cadmad
Re: LSZ caddy
Only seeing this. Yes literally disconnect yours plug sensor in to port then switch to sensor then run sensor to desired location.paul46 wrote:Is the auto light straight plug and play?
- dan@biali
- cadmad
Re: LSZ caddy
I will be sending a message shortly.
Re: LSZ caddy
Di not mean to offend, genuine response, it's type of mods i like (It's the Aberdonian in me) cracking vancadmad wrote:Yes same code on both. Refund from one and sent other back.
Thanks Kev for pointing out am a cheap ass lol.
- cadmad
LSZ caddy
No offence taken. Have to start somewhere only problem now is it leaves all the expensive stuff to do hahaKev23 wrote:
- cadmad
Re: LSZ caddy
Finally in and working. Getting air bag error which am guessing is because steering wheel not coded in anyone know if that is the case?
- cadmad
LSZ caddy
https://youtu.be/S1zQLLDXyZs" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Fault codes cleared steering wheel fully functioning
Purchased vcds so if anyone near me ( Derry N.Ireland) wants anything done give me a shout.
- cadmad
Re: LSZ caddy
Big thanks to Tommyzoom for looms and advise.
Re: LSZ caddy
That's what I want electric windows seems alot of work though if you have winders as standard. Are those mirror lights on the standard caddy mirrors? We're they easy to do?
- cadmad
Re: LSZ caddy
I had elec Windows already luckily. Yes puddle lights on standard mirrors. Very easy to do. As were door lights. Looms from Tommyzoom and fitting guides
Re: LSZ caddy
hi mate i have same year ex british gas , did you get rid of the limiter and if so is it hard to do ?
Re: RE: Re: LSZ caddy
im not sure when but after a certain time they started limiting it through the ecu.carlel wrote:hi mate i have same year ex british gas , did you get rid of the limiter and if so is it hard to do ?
mine is an 09 and was de-limited by a remapper
