van thinks back doors are open all the time
Driving to work this morning and back door open light comes on so I pulled over and checked it was shut which it was now the only time the light goes out is when I go over a bump but comes straight back on any body had this happen or no a fix its driving me mad already van is a 62 plate thanks in advance
- Barbel330
Re: van thinks back doors are open all the time
Dodgy connection on the door switch?
Instagram: @y_5cuf
That's what I thought so I removed the bottom latch when I got to work and refitted but no change I assumed the door sensor was in the bottom latch
- nicholas787
my bottom latch had a little bit of water pooled in it and that caused an 'always open' issue
Yes mine was wet this morning I have dried it out and light never came on when I traveled back from work did you find out where the water got in
Mine had water in it this morning dried it out and stopped the light for a bit did you find where the water was coming from
- nicholas787
I think it was just coincidental. Like I loaded some wet gear into the boot or something
Glad you've made some progress!
I’m having this problem, did drying it out solve all the problems?
Common issue for years in caddy. Trouble is that the loom plugs in to bottom latch down to it and the water travels down to the plug.
I got mine replaced under warranty as it was already badly corroded by the time I took it off to dry it.
Came up with this solution for it
- Mindak
I got the opposite issue, mine doesn’t know it’s opened so get no rear interior light when open and locks itself when I only go in the back after unlocking
So is it a case of replacing the whole bottom latch?
Mine ended up thinking back door was always shut so I have just left it like that
