Advise on multi function steering wheel please
- Dubbugmitch
Hi guys before I fork out on one i would like to know if this would work in my 2011 caddy, it hasn't got a multi function wheel as standard...so will this Modle work and be able to be coded to work with all features thanks in advance
Mitch
Mitch
Re: Advise on multi function steering wheel please
I would of thought so I had the golf r steering wheel fitted to mine but it had to be programed
Maybe give hazzy dayz a call they can confirm that's who supplied and fitted mine
- Dubbugmitch
walshyboy wrote:Maybe give hazzy dayz a call they can confirm that's who supplied and fitted mine
ok thanks ill give them a shout
Hard to tell from the photo but I'm assuming that's a mk7 GTD wheel. In which case it will not work.
The mk7 uses a different communication which is not backward compatible.
The new scirocco and polo use the older communication but the exact same style wheel. These will work with the correct module.
Sent from my Nexus 7 using Tapatalk
- Dubbugmitch
ok cheers doc! Thats good info ill get searching again then lol
mitch
mitch
- Dubbugmitch
Doc...would you mind taking a quick look at this and let me know if I'm on the right lines?
cheers Mitch
http://www.ebay.co.uk/itm/VW-GTI-Steeri ... SwGtRXzwYA" onclick="window.open(this.href);return false;
cheers Mitch
Yep, that'll work.
If you look at the description they mention the 6C polo, this is the one you want.
The 5G version is the mk7 that won't work.
Try Hazzy days for a price, just for comparison.
- Dubbugmitch
awesome thank you! i really wasn't sure on what i was looking at ha haDoc wrote:Yep, that'll work.
i have a mk7 gti working in mine will post a pic
Please do.
I'm interested to know how as there are some extremely intelligent guys who've gone to great lengths to make adaptors and signal converters.
If you can, post a photo with the bottons illuminated.
- Dubbugmitch
Are you still alright to put that pic up mate? be great to seejimmyq wrote:i have a mk7 gti working in mine will post a pic
- spacewalker
viewtopic.php?f=6&t=29284" onclick="window.open(this.href);return false;
