Battery Upgrade
tommyzooom
Re: Battery Upgrade
Post by tommyzooom » Sat Mar 25, 2017 8:33 pm
Picked this up today for £60 from local motor factors, ECP wanted double for it!
Sent from my C6603 using Tapatalk
phil
Re: Battery Upgrade
Post by phil » Sat Mar 25, 2017 8:53 pm
i ended up going down the mercedes route with my golf, thier batteries are made to ridiculously stringent specs as the can system in them is so sensitive, like doc i fitted the rigid battery box, looks so much better and not expensive from vw either i think i was circa £40 for the 3 parts
Bwj182
Re: Battery Upgrade
Post by Bwj182 » Fri May 19, 2017 7:04 pm
On a 2011 caddy 2l tdi do most people use a 096 battery? Different sites keep telling me different batteries
kully12
Re: Battery Upgrade
Post by kully12 » Mon Mar 11, 2019 10:53 pm
Doc wrote:Hi Alex,
I have a 096 battery in my Caddy and it fits the tray but not the soft cover.
I have fitted the ridgid battery box found on the earlier Caddys and golfs.
I plan to change my battery to the 096 as you guys have done so, as I believe it's on the way out, I've also had a new genuine alternator fitted due to bearing noises..
Any chance you could give me part numbers you used for the box in your caddy?? 3 parts so you say
Also just wanna make sure it will fit in my 1.6 2011 facelift 1.6 caddy 105bhp??
Thanks in advance
Barbel330
Re: Battery Upgrade
Post by Barbel330 » Mon Mar 11, 2019 11:15 pm
Have a look at Tayna batteries website if you're buying. Excellent service from them and quality batteries, not the usual crap from GSF or ECP. I just recently got a 096 Enduroline 78Ah after constantly suffering with battery drain during winter, that despite previously having a new battery from GSF. I've not suffered with any issues since fitting the new one. £80 I think I paid, well worth it.
It is a bigger sized battery si I'm interested if the battery boxes fit the larger size?
Instagram: @y_5cuf
kully12
Re: Battery Upgrade
Post by kully12 » Mon Mar 11, 2019 11:18 pm
Barbel330 wrote:Have a look at Tayna batteries website if you're buying. Excellent service from them and quality batteries, not the usual crap from GSF or ECP. I just recently got a 096 Enduroline 78Ah after constantly suffering with battery drain during winter, that despite previously having a new battery from GSF. I've not suffered with any issues since fitting the new one. £80 I think I paid, well worth it.
That's well priced!
Why did you choose that over the bosch one?
I want something that is juicy, won't let me down and will fit! Lol
Barbel330
Re: Battery Upgrade
Post by Barbel330 » Mon Mar 11, 2019 11:22 pm
I read lots of good reviews on that battery. So far so good :)
Instagram: @y_5cuf
kully12
Re: Battery Upgrade
Post by kully12 » Mon Mar 11, 2019 11:30 pm
Barbel330 wrote:I read lots of good reviews on that battery. So far so good :)
I'll do some reading, I was going to dive right into the bosch battery
Bionicman
Re: Battery Upgrade
Post by Bionicman » Tue Mar 12, 2019 11:02 am
Good price that Tommy, I cannot find one cheaper than that online.
kully12
Re: Battery Upgrade
Post by kully12 » Tue Mar 12, 2019 5:29 pm
Dont suppose you could help me with the part number for the rigid battery box?
Also which battery did you use?
kully12
Re: Battery Upgrade
Post by kully12 » Tue Mar 12, 2019 6:00 pm
Is this the Box btw?
Picture attached
battery box
Beaker2135
Re: Battery Upgrade
Post by Beaker2135 » Tue Mar 12, 2019 6:08 pm
Battery box
Trim - 3C0-915-335
Trim - 3C0-915-336-A
Cover - 3C0-915-443-A
They are the same as Golf and you can get Chineses ones off eBay for about £10
kully12
Re: Battery Upgrade
Post by kully12 » Tue Mar 12, 2019 6:22 pm
Battery box
Trim - 3C0-915-335
Thank you
Very much appreciated
Think I found the link online aswell:
https://www.ebay.co.uk/itm/VW-Battery-B ... ctupt=true
This above link is NOT GENUINE but a good aftermarket so the seller say.
Will check with TPS though now and get this sorted
Thank you!!
kully12
Re: Battery Upgrade
Post by kully12 » Tue Mar 12, 2019 7:59 pm
Ill post on this page how I get on.
The Bosch 096 and the 096 Enduroline (the one which you have) are the same size from what I can see.
I opted for the Bosch, and I will will speak to TPS tomorrow to get the box so will keep you posted how it goes
From the previous members replies, all should go all ok
Barbel330
Re: Battery Upgrade
Post by Barbel330 » Tue Mar 12, 2019 8:07 pm
Yes please do. Cheers.
Instagram: @y_5cuf
