caddy issues :(
caddy issues :(
hey guys ive got a 04 caddy 104 tdi, two weeks ago i went to start it one morning and it started as normal ran for about 2 seconds and then died, and did the same if if tryed again, it came up on diagnostics as engine position censer (crank censer), so the garage replaced the censer and got in running again at the cost of £200, however today the same problem returned and came up same problem on diagnostics so the garage is looking into it further, has anyone had the same problem at all and if possible shed any light on the situation??
many thanks
many thanks
- DADDY
Re: caddy issues :(
Had this with Traffics and Masters dude the crank angle sensor shows up a fault code. Change the sensor and vehicle runs for an unspecified period, Bang then back to square one. Renault now sell the multi-plug with gold-plated terminals, due to the low electrical resistance resistance of gold blaa de blaa. Anyway once these are changed out problem goes away, it sounds strange I know but I have done 10+ vehicles and none have ever come back with the crank sensor fault, so check the condition of this crank sensor plug just in case.
Re: caddy issues :(
Maybe a fault with the sensor connector plug/contacts rather than the sensor itself? Or maybe one of the wires leading to the sensor is slightly damaged/has chaffed on something??
Good luck.
Good luck.
Re: caddy issues :(
Had a similar problam with a 05 sdi last week was a broken wire from ecu 2 the crank sensor
Re: caddy issues :(
thank you!
- DADDY
Re: caddy issues :(
No worrys dude, hope this helps.risker wrote:thank you!
Re: caddy issues :(
ive just spoken to the garage and they say they have got to take the gearbox out because it could be something to do with the flywheel, ive heard the flywheels are pretty crap in caddys but its only done 65k so really not sure what to do as they havent started it yet, i havent used this garage befor so im not sure how trustworthy they are etc and not sure if there taking me for abit of a ride as i no nothing really....if any one has any surgestions it would be greatly appreciated thanku
cheers
cheers
Re: caddy issues :(
it seems to me ....clogged filter? gelling diesel? is very cold where you live?
only a guess!
only a guess!
Re: caddy issues :(
garage says its a prob with the fly wheel, but its been driving fine with no problems or noises at all so im just not sure myself how it can be a prob with the flywheel???
Re: caddy issues :(
crank sensor does not get a signal from the flywheel it reads off the crankshaft itself flywheels can give problems but does not stop engine running
- Hoggath
Re: caddy issues :(
NJQ. Can you confirm this if defiantly correct. It gets its signal from the crank itself and not the flywheel. Thanks Alex. Or anyone else can validate.
Re: caddy issues :(
The crank sensor gets it's signal from the rear crankshaft oil seal (yes, I know, quite bizzare, but I can assure you it does) the flywheel has nothing to do with it. P.S. I know because I've had experience of changing all of these components.
IF IT AIN'T BROKE, BREAK IT
- Hoggath
Re: caddy issues :(
Thanks very much. Counts out a comparability issue with the flywheel. Must have a broken wire in the loom.
Re: caddy issues :(
Do you know what diagnostic equipment they are using I have had a few experiences with snap on code readers getting crank and cam sensor mixed up so the wrong sensor gets replaced
- Hoggath
Re: caddy issues :(
Was a snap on solus. However sorted it now. Was a broken wire in the loom. 3 infact. Thanks.
