Air-con retrofit.
tommyzooom
Air-con retrofit.
Post by tommyzooom » Tue Jan 31, 2017 6:14 pm
I have been offered a damaged donor Caddy, albeit a maxi........ with air-con.
I have to dismantle the air-con myself though!
If anyone has already done this i'd appreciate any help on what to bring with me...
apart from the obvious... control panel, pump, heater box,pipework etc........what else, I assume there is cabin temp' sensors, outside temp' sensor, sunlight sensor, modules etc?????
A quick guide to taking out a dash too if possible.
gearoid
Re: Air-con retrofit.
Post by gearoid » Tue Jan 31, 2017 8:49 pm
Hi Andrew if its climatic it may not be so bad, climatronic is supposed to be more difficult. Stan should be able to point you in the right direction,it will be great to have a/c in the end
tommyzooom
Post by tommyzooom » Tue Jan 31, 2017 10:11 pm
Thanks.
Aircon panel is same as this.
@stan-the-man
Sent from my C6603 using Tapatalk
dan@biali
Post by dan@biali » Wed Feb 01, 2017 8:59 am
Is it still gassed? You have to be very careful if it is as the stuff is nasty and can be only be recovered by an authorised person as it's a greenhouse gas.
tommyzooom
Post by tommyzooom » Wed Feb 01, 2017 4:48 pm
I'm going to say no, lol
Beaker2135
Post by Beaker2135 » Wed Feb 01, 2017 5:43 pm
tommyzooom wrote:I'm going to say no, lol
:lol: :lol:
dan@biali
Post by dan@biali » Wed Feb 01, 2017 10:17 pm
Think you'll be alright
stan-the-man
Post by stan-the-man » Fri Feb 03, 2017 9:05 am
Just go for climatronic Andrew...
tommyzooom
Post by tommyzooom » Sat Mar 25, 2017 9:48 pm
I've been edging ahead with this as time allows.
I've changed the control panel to climatic, ordered the two extra sensors required,( but I didn't expect them to be €30 each!)
All parts are here, including new seals, new compressor oil, a new drier etc
I had the wiper motor out to fit an alarm siren, so took the opportunity to also fit the engine bay pipework, which went in surprisingly easy.(currently taped up and sealed from moisture)
Some wiring should come down both chassis legs, but access to drivers side is very hard to get to, so I've modified the AC engine loom, and all wiring will come down P/S
I stripped the donor loom and reduced it to a retrofit AC loom, I'm going to replace the battery tomorrow, so might take the opportunity to thread this loom through bulkhead grommet and into position, It'll be another job done.
tommyzooom
Post by tommyzooom » Sat Mar 25, 2017 9:50 pm
From this....
To this....
phil
Post by phil » Sun Mar 26, 2017 12:53 am
With all the effort you're going to why not go climtronic ;)
ckvan
Post by ckvan » Sun Mar 26, 2017 11:29 am
What is the benefit of climatronic and can it be upgraded from a climatic system ?
phil
Post by phil » Sun Mar 26, 2017 11:41 am
Climatronic is a dual zone control and can regulate temperatures set by either passenger. It can be upgraded I'm in the process of doing this on my golf mk6 but it requires the dash out to achieve the end result as a new heater blower unit needs fitting with extra motors. As I've not seen them both side by side yet I cannot say if the motors themselves are retrofitable to an existing single zone unit perhaps doc can comment?
Post by Doc » Sun Mar 26, 2017 1:13 pm
The climatronic airbox has extra internal ducts and baffles to operate the dual zone.
If i were doing the conversion and getting in that deep I'd go the whole way to climatronic. With that said, in a van with a solid bulkhead it's not going to create that different of a climate from one side to the other.
tommyzooom
Post by tommyzooom » Sun Mar 26, 2017 4:21 pm
phil wrote:With all the effort you're going to why not go climtronic ;)
While it would be nice, finding a donor Caddy with climatronic would be hard, you cannot just upgrade what I have, new airbox etc is required.....
Apart from the extra sensors, and sundry parts, it didn't cost too much, apart from a half day removing...
My passenger seat is very seldom sat on. As Doc said, I'd also be sceptical how climatronic would be much benefit. I'm trying to think of the comedian, who had a routine on Aircon, how it was -5 on one side, and 25c on the other side of the car :)
