Retrofit adaptive cruise control - possible?
somacose
Post by somacose » Sun Feb 12, 2017 12:15 am
Is it possible to retrofit adaptive radar cruise control as featured on certain new MK4 caddys to a MK3 highline caddy with the bog standard stalk controlled cruise control?.
If so then what items would be needed and what sort of expense?, stupidly expensive or outrageously expensive? :D
2013 Caddy Highline superchipped but still no match for my Mk2 Golf GTI
maxx007at
Re: Retrofit adaptive cruise control - possible?
Post by maxx007at » Sun Feb 12, 2017 6:56 am
I think it should be possible. On a facelift you'd have to replace the stalks. The radar module only has 4 wires, plus, earth and CAN HIGH, CAN LOW.
However, on a prefacelift, you'd have to replace the steering colum as well.
Not sure about coding of your ECU though, maybe some others know about that.
Post by Doc » Sun Feb 12, 2017 9:27 am
It is possible, MartyPL fitted it on his Caddy I believe. Spacewalker definitely has retrofitted it on his 2005 Touran.
He had to change his stalks as he had the older version.
I think you need support in ECU and ABS.
somacose
Post by somacose » Sun Feb 12, 2017 11:43 am
Damn....sounds like it is "relatively" simple/easy to do without the need to sell a kidney for funds, I'll probe the mind of my relatively local VW geek and take it from there.
Many thanks peeps, appreciated.
dan@biali
Post by dan@biali » Sun Feb 12, 2017 11:59 am
If you look on ebay for VW adaptive cruise it brings up a few parts for Golfs and Passats which gives a clue as to what might need to be changed. On top of the stalks, there's a camera (the radar) that goes in the grill, an ecu which controls it all (possibly done on the slip ring in the Caddy) and the ABS pump. There's also a harness to connect to the gauge cluster but not sure if thats possible on the Caddy. Whether the Caddy version is as complicated as a Passat for example I don't know. What was a surprise was the price of the parts isn't insane, well secondhand ones anyway! ECU can be bought for £100 although brand new they're £800, if its the slip ring then about the same price. ABS pump looks like its about £100 as well. When I get etka up and running again (problem updating means I can't open it) I'll look for some part numbers.
Aikon
Post by Aikon » Sun Feb 12, 2017 2:37 pm
I looked to add it as an extra on the Caddy I've got coming in April but you can't select it without MFSW & Satnav, neither of which I wanted so it became an expensive option.
somacose
Post by somacose » Mon Feb 13, 2017 5:11 pm
Cheers dan, that'd be a great help, I'd prob go to the extra expense of fitting a suitable mfsw at the same time - i used to have a copy of etka years ago when i was messing about with my corrado's/scirocco's and mk2's, may enquire through a mate if i can "borrow" his copy
dan@biali
Post by dan@biali » Mon Feb 13, 2017 7:10 pm
Bits I've found on etka so far:
2K5 907 561 B - control unit with software for distance regulation and radar sensor £400
That looks like it includes - 2K5 998 561 repair set radar sensor
7E0 614 517 L BEF - ABS unit with control unit filled and vented £1600
somacose
Post by somacose » Mon Feb 13, 2017 8:24 pm
£2k....Eeeek! :shock: , Hmm - I guess i'll have to rely on 2nd hand parts if i decide to go down that route.
dan@biali
Post by dan@biali » Mon Feb 13, 2017 9:37 pm
That 7E0 number could be handy as that's likely to be a universal part fitted to more than one VAG vehicle. I'll keep my eye on this thread if there are other parts people tell us about and as etka back up and running I can look them up.
phil
Post by phil » Wed Feb 15, 2017 12:57 pm
keep in mind these units need adaptation on a vehicle and not a lot of places have the equipment to do it.
hella offer a system but its ££££'s
E-Bagge
Post by E-Bagge » Thu Jan 10, 2019 12:11 am
Anyone succeeded in pulling this one off?
