Cable route thru firewall
Liam
Post by Liam »
Guys im looking for advice from those in the know
I need to run a single wire from my light switch out thru the firewall of the van to get to the battery tray to connect to my foglight relay does anyone know of any good options or tips as to whete to get access ? Its a 2012 model
Build thread here
mostlysimon
Re: Cable route thru firewall
Post by mostlysimon »
If it's the same as the pre-face lift, there's a grommet through to the engine bay under the 'glove box', you just have to remove the piece of foamy sheet and pull the carpet back to access it. A technical poke with a screwdriver will allow enough room to feed a cable through.
Liam
Post by Liam »
Cheers for that il have to investigate
Build thread here
TDean122
Post by TDean122 »
It could be the same grommet it's mentioned above I think it's the grommet for a left hand drive bonnet cable. If you look at the left of the van where the strut top mount is look in there you will see a grommet. I removed glove box and then pushed a little wire routing rod through and got it
Liam
Post by Liam »
Nice one thank you
Build thread here
Dsport
Post by Dsport »
I had the same issue couldn't find a way through on the drivers side, the only grommet I could find went through into the arch I think, so took the metal sctttle cover off, and there is a couple of grommets there,
Liam
Post by Liam »
@dsport
Is that the metal panel under the windscreen is where the ecu is ?
Build thread here
ekeamonn
Post by ekeamonn »
Did you get this sorted Liam? Im having the same issue myself and am confused where the best place to bring it in is, to wire it to the light switch.
shanky887614
Post by shanky887614 »
Best place is the grommet above the pedals
I wouldn't say the grommet above the pedals is the best place, there is zero access on the engine bay side and the loom could easily be damaged by blindly forcing something through the rubber.
ekeamonn
Post by ekeamonn »
I was looking at the glove box side but the loom i have isnt long enough to reach to the switch so i might have to modify it a bit.
tommyzooom
Post by tommyzooom »
I've a spare loom I'm messing with....
This is a pic of the glovebox side grommet, usually hidden by the battery.
You can see there are "nipples" for adding extra wires
Sent from my C6603 using Tapatalk
I posted some photos of how I ran two cables through the passenger side grommet.
HERE
Maxi4life
Post by Maxi4life »
I tried today to fit my fog light loom, but come stuck and cannot route the wires via passenger side as the loom is not that long.
I managed to poke in a grommet up above the ds bonnet hinge, I'll have another go tomorrow but surely its just as easy to use a holesaw and a matching grommet from the bay of e.
Maxi4life
Post by Maxi4life »
This is how I routed my cable today. Very tricky to get combi drill in there but managed it going from a 3mm bit then 5mm bit then 25mm holesaw.
