Flashing glow plug light
Hi, what would it mean my glow plug light flashing? Started flashing on my way home from work today now got me worried
- maxx007at
Re: Flashing glow plug light
ECU error, it's now running in safe mode.Mattholder20 wrote:Hi, what would it mean my glow plug light flashing? Started flashing on my way home from work today now got me worried
Probably you have lack of power now?
Yes mate, just happened again and went in to limp mode, how can this be resolved?maxx007at wrote:ECU error, it's now running in safe mode.
- maxx007at
I'd suggest having someone read it out with a computer, either someone with VCDS or a garage. Limp mode can have a couple of causes, so I don't know without dataMattholder20 wrote: Yes mate, just happened again and went in to limp mode, how can this be resolved?
Ok mate thsnksmaxx007at wrote:I'd suggest having someone read it out with a computer, either someone with VCDS or a garage. Limp mode can have a couple of causes, so I don't know without data
- Davebass
this happened to mine when i first got it over a year ago and it ended up being the egr valve ,
i got a new one fitted and went again recently so got it mapped out no problem since ,
cheaper to map it out than get a new egr
flashing glow plug light can be a general fault,get it read with a simple diagnostic tool ,most common faults are faulty injector,egr valve or brake light switch(check your brake light function yourself by pressing brake pedal n see if lights come on).most common fault however is faulty fuel injector, if its this fault the injectors are expensive €300 -€400 each but don't despair because there not too difficult to fit, its a job you could do yourself, just done some yesterday so if its injector fault let me know n ill run you through the process.
Thanks guys, had someone plug it in and have a look, had no error codes or nothing come up and has ran nicely since, so im quite confused!
