Sliding door removal
Does anyone know the easiest way to remove the side door ? Can't seem to find anything in the "how to" section, thanks for looking. GT
- Arsenalgun
Re: Sliding door removal
To remove sliding door you will need to undo the 2x multi spline bolts at the bottom runner (look bottom far right of the runner) the door catch that holds the door open remove this. Then undo 3 of the multi spline bolts that hold the middle runner pull and slide the end cap off and pull the runner out slightly for clearance then just slide the door of its runnersGaryt65 wrote:Does anyone know the easiest way to remove the side door ? Can't seem to find anything in the "how to" section, thanks for looking. GT
