Hi guys.
Fitted a golf r mk 7 MFSW and SWCM from same vehicle but non of it works.
Once all connected I cant access steering wheel module in vcds
When connected to the original swcm, VCDS will then connect to the control module but coding will not be accepted for MFSW.
Does this need the additional wires connected between The SWCM and BCM
any help would be great.
Mfsw retrofit
- spacewalker
Re: Mfsw retrofit
viewtopic.php?f=6&t=29284&p=251756#p251756" onclick="window.open(this.href);return false;
