caddy 2013 tpms intall vcds
pnd
Re: caddy 2013 tpms intall vcds
Post by pnd » Sun Jan 06, 2019 9:23 am
Hi!
I'm new member and can't see some threads of this forum, so I have to ask for help here.
I believe I have 2013 Caddy 1.2TSI and tried to enable indirect TPMS with no luck (
My ABS brakes block and module is:
Code: Select all
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BL    HW: 1K0 907 379 BL
   Component: ESP MK60EC1   H31 0152
   Revision: 00H31001
   Coding: 423C200D09288000421204E7901B0140310800
   Shop #: WSC 35110 377 00146
   VCID: 7DF14FF5E4F169A2BE-8028
I"m trying to enable bits 1 and 2 in Byte 16, but module rejects coding with Error 31 - request out of range. Bit 2 in Byte 17 enables fine.
I would appreciate any suggestions
Dmitry
magna413
Post by magna413 » Sun Jan 06, 2019 11:32 am
Hi!
Dmitry
I think code You should try would be:
Code: Select all
423C200D09288000421204E7901B0140370800
This should be the on You tried.
Also try this:
Code: Select all
423C200D09288000421204E7901B0140B70800
If doesn't work, revert to original.
Le VW Freaks - Our Hobby for VW Cars.
pnd
Post by pnd » Sun Jan 06, 2019 10:00 pm
Code: Select all
I have already tried this exact coding and module refuses to take it.
Also try this:
Code: Select all
I will try it and post a result. Thanks for your input!
pnd
Post by pnd » Mon Jan 07, 2019 6:04 pm
Also try this:
Code: Select all
Still no luck ( Error 31 - request out of range
