does anybody know if there is a way of getting the passenger door open if the handles don't work ,
i think the cable has dropped off as I've slammed the door shut,
I'm in the middle off fitting electric windows and incorrectly attached cable and its not working
door is now stuck shut oops
any help would be appreciated thanks
passenger door!
- Davebass
passenger door!
If you have the lock barrel out you could possibly grab the cable on the door lock and unlatch same for passenger side.
Otherwise you will need to take door trim off from inside which is a biach the unbolt regulator carefully to give you enough room to operate the latch
- Davebass
Re: passenger door!
so after a lil patience and a welding rod and youtube I've got the door open
- Kimtins
Re: passenger door!
Thank heavens for YouTube eh!
Sent from my Nexus 6P using Tapatalk
- Davebass
Re: passenger door!
yea defo bit of a lifesaver sometimes lol
