passenger door!
Davebass
passenger door!
Post by Davebass »
does anybody know if there is a way of getting the passenger door open if the handles don't work ,
i think the cable has dropped off as I've slammed the door shut,
I'm in the middle off fitting electric windows and incorrectly attached cable and its not working :shock:
door is now stuck shut oops :)
any help would be appreciated thanks
grtuned
passenger door!
Post by grtuned »
If you have the lock barrel out you could possibly grab the cable on the door lock and unlatch same for passenger side.
Otherwise you will need to take door trim off from inside which is a biach the unbolt regulator carefully to give you enough room to operate the latch
Davebass
Re: passenger door!
Post by Davebass »
so after a lil patience and a welding rod and youtube I've got the door open :)
Kimtins
Re: passenger door!
Post by Kimtins »
Thank heavens for YouTube eh!
Sent from my Nexus 6P using Tapatalk
Davebass
Re: passenger door!
Post by Davebass »
yea defo bit of a lifesaver sometimes lol
