What seats are best?
Hi all,
Thinking of upgrading the awful standard caddy seats. Thinking Touran or Passat.
Not looking to spend a lot and want comfy, easy fit seats.
WHYG or would you suggest?
Ben
Ben
Re: What seats are best?
Not sure if you have seen this but hope this helps
https://www.caddy2k.com/forum/viewtopic.php?t=30537" onclick="window.open(this.href);return false;
Sent from my SM-G900F using Tapatalk
Managed to get some touran seats and centre console with hand brake sorted for £200. Fitting them Friday ! Hopefully it's not to hard.
Mind post some b4 and after pics
Will try to. Need to sort out a photo bucket account or tap talk.geo.stronach wrote:Mind post some b4 and after pics
Tap talk much easier for you
Before
After
Waiting on matching dark grey handbrake and then need to get the seats cleaned!
After
On the touran centre console mod does this require taking out the plastic around the gear stick and esp button? Or does a touran centre clip into the caddy original part?
Yes it all has to come out! Well unless I did something wrong lol!Bwj182 wrote:On the touran centre console mod does this require taking out the plastic around the gear stick and esp button? Or does a touran centre clip into the caddy original part?
Ok thanks for advice. I miss not having an armrest so need to get one sorted soon.
There is a good 'how to' in the technical section! I did mine before I had access to there! It would have been so much easier if I had of had the guide while doing it!Bwj182 wrote:Ok thanks for advice. I miss not having an armrest so need to get one sorted soon.
Also does anyone know if the earlier touran 2004 seat bases and centre console fit in a 2011 caddy?
I've posted this pic elsewhere but I've fitted Audi A1 seats. Picked up front and rear seats on eBay for £200 so worked out very cheap especially as I've sold the originals and the rear Audi ones.
Straight swap too so about a 15 minute job. Much more comfort and they tilt so can access the storage underneath easier.
- Ske
Looks well swanky!
