Just plugged a USB for the first time into my fag lighter socket while the ignition was off,and there was power .
Is that right,I thought they should only come on with the ignition to stop battery drain if you leave something in the socket?
2012 Caddy.
Sent from my HTC One M9 using Tapatalk
Fag lighter socket.....
Re: Fag lighter socket.....
That is right - permanent power.
- Beaker2135
Yep permanent live
I've piggybacked a USB charger to mine and there is no noticeable drain
