Raven blue - colour code
Hi was wondering does any one know the colour code for the Raven Blue caddy, it's not on the plastic trim under steering wheel?
- tommyzooom
Re: Raven blue - colour code
LA5W...
Thanks tommyzooom,
I'm for spraying the rear VW badge Matt black, wanting the back part same colour as the van, any tips for the chrome part?
- tommyzooom
I recently did mine gloss black. I'm no painter, but i did...
lightly sand the chrome, to provide a key.
Plastic primer
Grey primer
Colour
Lacquer
Plastic primer
Grey primer
Colour
Lacquer
- gfc
Hi I'll have a look for you tomorrow as it's absolutely pi***ng down here and much as I love you all I've got my 'jamas on.
I'll get back to you if I can find it.
All the best
George
All the best
George
Any photos of yours done gloss Black, I'm starting to think it mite look better, was aiming along the lines of getting alloys side bars an maybe roof rails an getting them all spayed Matt black but now I'm unsure
- tommyzooom
Yeah. In my build thread.Caddyguy84 wrote: ↑Wed May 17, 2017 9:24 pm Any photos of yours done gloss Black, I'm starting to think it mite look better, was aiming along the lines of getting alloys side bars an maybe roof rails an getting them all spayed Matt black but now I'm unsure
Try plasti dip that way if you don't like it just peel it off and start again
Sent from my SM-G900F using Tapatalk
Cheers tommyzooom il have a look.tommyzooom wrote: Yeah. In my build thread.
Yea heard of that plasti dip would it not chip off?geo.stronach wrote:Try plasti dip that way if you don't like it just peel it off and start again
No its hardy stuff my friend has his gti wheels done white for past 6months and still not a mark on them
Youtube the stuff ul be amazed
Cheers bud il have a look on you tube eregeo.stronach wrote:Youtube the stuff ul be amazed
I had plasti dip on my front grill of a honda accord for about two years with very few marks, just the odd stone chip. Rear badge should get a lot less hard. If you want permanent I'd use plastikote... I have used it on loads of plastic things in the past and it's good stuff
Cheers pal I ended up just going for the spray hopefully it will turn out ok, il get pics up when it done.Bwj182 wrote:I had plasti dip on my front grill of a honda accord for about two years with very few marks, just the odd stone chip. Rear badge should get a lot less hard. If you want permanent I'd use plastikote... I have used it on loads of plastic things in the past and it's good stuff
