Page 1 of 2
Reversing Camera Options Caddy4
Posted: Mon Jul 10, 2017 11:56 pm
by DJOHALL
As the title says, looking to find out what's on the market to retro fit a reversing camera to a 2016 caddy. I've check as much as I can online and can't find anything except for a company in Austraila. I have seen some people have done it but I can't find a parts list or any detailed info. Any help would be greatly appreciated!
Re: Reversing Camera Options Caddy4
Posted: Tue Jul 11, 2017 4:51 am
by audiobull
I too would be interested for a gen 4, not sure if there is much difference. I have seen cheapo camera's on ebay but not sure if they will link up.
It would be good to know of a cheaper source for genuine camera's too.
I have the discover headunit so would be good to be able to link it up to that.
Posted: Tue Jul 11, 2017 6:06 am
by spacewalker
parts can be find in Etka , simple compare Caddy with T6 or latest Sharan / Tiguan/Jetta/ who use this same radio
Posted: Tue Jul 11, 2017 9:25 am
by feherb
I installed one original camera for discover media. The total cost was 136 EUR. (camera 75 EUR+ wires 60 EUR) I ordered it on this site:
http://www.vwmodul.de/. It works well.
After that, I read an other solution on a german site.
https://www.motor-talk.de/forum/rueckfa ... 39208.html
Aftermarket camera 30 EUR
https://www.amazon.de/MAYA-R%C3%BCckfah ... B01G3134FC
Aftermarket wires 10 EUR:
https://www.amazon.de/gp/product/B01MED5F76
One filter 15 EUR
https://www.amazon.de/gp/product/B00BN5ZD94
Posted: Wed Jul 12, 2017 12:00 am
by DJOHALL
That's perfect, thank you. I must try locate someone near me that can activate it when I've it all fitted.
Posted: Wed Jul 12, 2017 8:05 am
by Kaddy2koz
Here's a thought for you all. I mounted a 120deg camera in the rear door on the glass (double-sided tape with a hole in the middle for the lens). I wired it in to the right hand side up to behind the drivers seat. I mounted an LCD screen on the load board, in the centre looking forward. I ran battery to the wiring behind the drivers seat for the cam and the monitor. Now, when I look in the rear view mirror I see OUTSIDE the rear windows in the LCD screen, not THROUGH the rear windows. Rear view and reversing (without warnings of course). I also have a tennis ball hanging in the garage that I back up onto, until it rests against the glass opposite the lense. Cost - all second hand from wherever.
Posted: Wed Jun 05, 2019 8:28 am
by Korky
Is there a genuine oe option for this with the discover media unit?
Posted: Wed Jun 05, 2019 12:42 pm
by Doc
For the tailgate caddy only I believe. I don't recall ever seeing a factory reversing camera on a wing door caddy.
Posted: Wed Jun 05, 2019 2:25 pm
by skinnyd
Korky wrote:Is there a genuine oe option for this with the discover media unit?
This is oe part. Fits the barn door without buying the extra handle as you just need to cut it.
http://vagtec.co.uk/eshop/vw-commercial ... dy-sa.html
Posted: Wed Jun 05, 2019 2:41 pm
by Korky
Thanks for this, great find! I’ll have to get one ordered
Posted: Thu Jun 06, 2019 9:25 pm
by Astrohunter
For those after a budget option i have just fitted a £38 kit from Amazon.
Put the camera just above the number plate on barn doors. I added a switch on the dash as like to see behind sometimes when not reversing. Its just as clear on the included screen as one i fitted to a motorhome that cost over £200.
Bargain at that price.
AUTO-VOX M1 Car Reversing Camera Rearview Backup Camera IP68 Waterproof Night Vision Kit,4.3'' TFT LCD Rear View Monitor Parking Assistance System with One Wire Easy Installation
https://www.amazon.co.uk/dp/B071D9TWSG/ ... -CbAMXH7WR
Posted: Thu Jun 06, 2019 11:41 pm
by LTCKY
I’ve done mine, as long as you have discovery Media. OEM style interface, which does need coding with VCDS, this supplies a ignition and reverse feed (so no need to find reverse wire in back)£85.00 and small camera that needs a hole drilled in number plate plinth £30.00
Posted: Fri Jun 07, 2019 7:13 am
by Korky
LTCKY wrote:I’ve done mine, as long as you have discovery Media. OEM style interface, which does need coding with VCDS, this supplies a ignition and reverse feed (so no need to find reverse wire in back)£85.00 and small camera that needs a hole drilled in number plate plinth £30.00
Do you have the link to those mate, that might save me a few £
Posted: Fri Jun 07, 2019 7:44 am
by LTCKY
They are from one of my Trade suppliers, give me a email or call from my Bio
Posted: Wed Jun 12, 2019 12:36 pm
by Korky
LTCKY wrote: ↑Fri Jun 07, 2019 7:44 am
Hi mate, can’t see your email or details in bio?
