caddy 1.6 tdi
caddy 1.6 tdi
any 1 no whats needed to do a converstion from 1.6 tdi to 2.0 cr engine is it a straight swap can i just get a 2.0 cr engine loom and ecu and be away, oviously id need to sort the immobiliser out
Re: caddy 1.6 tdi
Hi and welcome to the forum.
There are few engine changes that can be described as a straight swap.
Considering the engines use different ECUs, I suspect the wiring or pinout at the ECU will be different at an absolute minimum.
Re: caddy 1.6 tdi
thanks for that il have a look see if i can find anything on elsawin
