Are these factory reversing camera wires? Took cover off the lhs rear door and found these wires
free image upload api
Reverse camera wires
Re: Reverse camera wires
From that lot one runs up to just behind the numberplate lights and its been cut
They will be aftermarket.
The factory reversing camera is not fitted to barn door, only tailgate versions.
- Philt32
I knew I shouldn't have built my hopes upGeraout wrote:They will be aftermarket.
Yes but someone has done the hard bit for you - running the wiring through the van.
Its worth a check for the cables at the head unit end and then all you need is a camera....
I didn't notice any unexpected wires at the head unit when i changed speakers. Will have to have another look
