sat nav/ radio
sat nav/ radio
Hi all I have been thinking of upgrading my radio in my 2011 caddy. Would a SEAT RNS315 DAB GPS fit and work ok. Would I need to buy any looms etc. Thanks in advance.
Re: sat nav/ radio
Hi I've just fitted a vw one of these best to my knowledge they are the same just the start up screen is different i.e. Seat not vw
I just plugged straight in to the original quad lock harnesses that the old radio was fitted to.
You will need a gps antenna for the sat nav
If it has dab you will need a dab antenna and if you want to make call with Bluetooth (if it has it ) You will need a microphone.
This is what I am fitting this weekend to the rns 315 so I can use all of its functions.
Hope this helps
Hope this helps
Re: sat nav/ radio
hi re there microphone how did you connect it up ? we have a toucan 2006 radio rns mfd dvd
,harness powers up etc but there inso microphone connection?
- djandyk
Re: sat nav/ radio
i an struggling with microphone
Re: sat nav/ radio
The microphone is two wires, it's difficult to get it wrong in fairness. Have you connected to the correct terminals on the quadlock plug?
