What seats will just drop into my caddy without having to mess about with the wiring?
It has side airbags/heated seats, I'm after some leather seats but don't want anything heavily bolstered. I have got a set of Touran bases here hopefully to make it a little easier!
Plug and play seats for 2017 Caddy Highline
Re: Plug and play seats for 2017 Caddy Highline
None other than caddy made for your generation van unfortunately
Cheers Stan, what are the easiest to adapt to fit the Caddy?stan-the-man wrote:None other than caddy made for your generation van unfortunately
Put simply, any same era VW seats with the same "features" as your caddy will be the same amount of work.
Heater & Airbag plugs will need adaptors.
Cheers Doc. Are the adapters available to buy or is it a case of making them up?
I'm after a comfortable set of seats, any recommendations?
You'd have to get them made up to suit your application.
